I’m new to geoserver…
try to add cog plugin in geoserver by following +https://docs.geoserver.org/latest/en/user/community/cog/cog.html#:~:text=COG%20(Cloud%20Optimized%20GeoTIFF)%20is,issuing%20HTTP%20GET%20range%20requests.+
but getting HTTP ERROR 503 Service Unavailable on *[http://localhost:8080/geoserver/*](http://localhost:8080/geoserver/*)
not sure it’s a BUG or miss from my end.
error log
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘requestMappingHandlerAdapter’ defined in org.geoserver.rest.RestConfiguration: Bean instantiation via factory method failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter]: Factory method ‘requestMappingHandlerAdapter’ threw exception; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:627)
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:456)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1318)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1158)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:554)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:514)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:321)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:319)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:199)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:866)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:878)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:550)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:401)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:292)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:1068)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:572)
at org.eclipse.jetty.server.handler.ContextHandler.contextInitialized(ContextHandler.java:997)
at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:746)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:379)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1457)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1422)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:911)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:288)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:524)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:73)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:46)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:188)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:517)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:157)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:173)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:427)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:66)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:785)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:754)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:641)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:540)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:146)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:605)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:252)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
at org.eclipse.jetty.server.Server.start(Server.java:423)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:97)
at org.eclipse.jetty.server.Server.doStart(Server.java:387)
at org.eclipse.jetty.xml.XmlConfiguration.lambda$main$3(XmlConfiguration.java:1907)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1857)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:218)
at org.eclipse.jetty.start.Main.start(Main.java:491)
at org.eclipse.jetty.start.Main.main(Main.java:77)
Caused by: org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter]: Factory method ‘requestMappingHandlerAdapter’ threw exception; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:185)
at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:622)
… 60 more
Caused by: javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
at javax.xml.stream.FactoryFinder.find(FactoryFinder.java:324)
at javax.xml.stream.XMLOutputFactory.newFactory(XMLOutputFactory.java:263)
at com.fasterxml.jackson.dataformat.xml.XmlFactory.<init>(XmlFactory.java:124)
at com.fasterxml.jackson.dataformat.xml.XmlFactory.<init>(XmlFactory.java:101)
at com.fasterxml.jackson.dataformat.xml.XmlFactory.<init>(XmlFactory.java:92)
at com.fasterxml.jackson.dataformat.xml.XmlMapper.<init>(XmlMapper.java:141)
at org.springframework.http.converter.json.Jackson2ObjectMapperBuilder$XmlObjectMapperInitializer.create(Jackson2ObjectMapperBuilder.java:869)
at org.springframework.http.converter.json.Jackson2ObjectMapperBuilder.build(Jackson2ObjectMapperBuilder.java:628)
at org.springframework.http.converter.xml.MappingJackson2XmlHttpMessageConverter.<init>(MappingJackson2XmlHttpMessageConverter.java:50)
at org.springframework.http.converter.support.AllEncompassingFormHttpMessageConverter.<init>(AllEncompassingFormHttpMessageConverter.java:86)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.<init>(RequestMappingHandlerAdapter.java:208)
at org.springframework.web.servlet.config.annotation.WebMvcConfigurationSupport.createRequestMappingHandlerAdapter(WebMvcConfigurationSupport.java:594)
at org.springframework.web.servlet.config.annotation.WebMvcConfigurationSupport.requestMappingHandlerAdapter(WebMvcConfigurationSupport.java:562)
at org.geoserver.rest.RestConfiguration$$EnhancerBySpringCGLIB$$2ffee544.CGLIB$requestMappingHandlerAdapter$10(<generated>)
at org.geoserver.rest.RestConfiguration$$EnhancerBySpringCGLIB$$2ffee544$$FastClassBySpringCGLIB$$27037470.invoke(<generated>)
at org.springframework.cglib.proxy.MethodProxy.invokeSuper(MethodProxy.java:244)
at org.springframework.context.annotation.ConfigurationClassEnhancer$BeanMethodInterceptor.intercept(ConfigurationClassEnhancer.java:363)
at org.geoserver.rest.RestConfiguration$$EnhancerBySpringCGLIB$$2ffee544.requestMappingHandlerAdapter(<generated>)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:154)
… 61 more
2022-04-11 23:55:00.827:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext@anonymised.com
{GeoServer,/geoserver,file:///Users/ajay/geoserver/webapps/geoserver/,UNAVAILABLE} {/Users/ajay/geoserver/webapps/geoserver}
Caused by:
Caused by:
2022-04-11 23:55:00.861:INFO:oejs.AbstractConnector:main: Started ServerConnector@anonymised.com
{HTTP/1.1, (http/1.1)} {0.0.0.0:8080}
2022-04-11 23:55:00.866:INFO:oejs.Server:main: Started @16548ms
Thanks
