[Geoserver-devel] [JIRA] (GEOS-10474) OpenID Connect fails with error "Provider for javax.xml.stream.XMLOutputFactory cannot be found"
Andre Zielinski created an issue
GeoServer / BugGEOS-10474
OpenID Connect fails with error “Provider for javax.xml.stream.XMLOutputFactory cannot be found”
Issue Type:
BugBug
Affects Versions:
2.19.6, 2.20.4
Assignee:
Unassigned
Components:
OAuth2
Created:
27/Apr/22 9:31 AM
Environment:
Windows Server 2019 with Redhat JRE 8 and Apache Tomcat 9.0.62
Priority:
MediumMedium
Reporter:
Andre Zielinski
When upgrading ot the latest GeoServer installation (2.20.4 or 2.19.6) the integration of the auth2-openid-connect-plugin fails with the following error message:
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'authenticationManager' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Prod/Tomcat9_0_58/webapps/geoserver_test/WEB-INF/lib/gs-main-2.20.4.jar!/applicationSecurityContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'openidConnectAuthenticationProvider' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Prod/Tomcat9_0_58/webapps/geoserver_test/WEB-INF/lib/gs-sec-oauth2-openid-connect-2.20-SNAPSHOT.jar!/applicationContext.xml]: Bean instantiation via constructor failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.security.oauth2.OpenIdConnectAuthenticationProvider]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'openIdConnectTokenServices' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Prod/Tomcat9_0_58/webapps/geoserver_test/WEB-INF/lib/gs-sec-oauth2-openid-connect-2.20-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.security.oauth2.services.OpenIdConnectTokenServices]: Constructor threw exception; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:602)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:516)
	at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:324)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:322)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202)
	at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1109)
	at org.geoserver.platform.GeoServerExtensions.getBean(GeoServerExtensions.java:209)
	at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:126)
	at org.geoserver.platform.GeoServerExtensions.bean(GeoServerExtensions.java:288)
	at org.geoserver.platform.GeoServerExtensions.bean(GeoServerExtensions.java:272)
	at org.geoserver.config.util.XStreamPersister.getSecurityManager(XStreamPersister.java:634)
	at org.geoserver.config.util.XStreamPersister$StoreInfoConverter.doUnmarshal(XStreamPersister.java:1870)
	at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:277)
	at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72)
	... 142 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'openidConnectAuthenticationProvider' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Prod/Tomcat9_0_58/webapps/geoserver_test/WEB-INF/lib/gs-sec-oauth2-openid-connect-2.20-SNAPSHOT.jar!/applicationContext.xml]: Bean instantiation via constructor failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.security.oauth2.OpenIdConnectAuthenticationProvider]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'openIdConnectTokenServices' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Prod/Tomcat9_0_58/webapps/geoserver_test/WEB-INF/lib/gs-sec-oauth2-openid-connect-2.20-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.security.oauth2.services.OpenIdConnectTokenServices]: Constructor threw exception; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
	at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:314)
	at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:295)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1361)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1208)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:556)
	at org.geoserver.security.GeoServerSecurityManager.lookupSecurityProviders(GeoServerSecurityManager.java:2613)
	at org.geoserver.security.GeoServerSecurityManager.buildPersister(GeoServerSecurityManager.java:2673)
	at org.geoserver.security.GeoServerSecurityManager.setApplicationContext(GeoServerSecurityManager.java:353)
	at org.springframework.context.support.ApplicationContextAwareProcessor.invokeAwareInterfaces(ApplicationContextAwareProcessor.java:123)
	at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:100)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:415)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1791)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:594)
	... 156 more
Caused by: org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.security.oauth2.OpenIdConnectAuthenticationProvider]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'openIdConnectTokenServices' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Prod/Tomcat9_0_58/webapps/geoserver_test/WEB-INF/lib/gs-sec-oauth2-openid-connect-2.20-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.security.oauth2.services.OpenIdConnectTokenServices]: Constructor threw exception; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
	at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:220)
	at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:117)
	at org.springframework.beans.factory.support.ConstructorResolver.instantiate(ConstructorResolver.java:310)
	... 176 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'openIdConnectTokenServices' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Prod/Tomcat9_0_58/webapps/geoserver_test/WEB-INF/lib/gs-sec-oauth2-openid-connect-2.20-SNAPSHOT.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.security.oauth2.services.OpenIdConnectTokenServices]: Constructor threw exception; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1323)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1218)
	at org.geoserver.security.oauth2.GeoServerOAuthAuthenticationProvider.<init>(GeoServerOAuthAuthenticationProvider.java:50)
	at org.geoserver.security.oauth2.OpenIdConnectAuthenticationProvider.<init>(OpenIdConnectAuthenticationProvider.java:21)
	at sun.reflect.GeneratedConstructorAccessor690.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
	at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:207)
	... 178 more
Caused by: org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.security.oauth2.services.OpenIdConnectTokenServices]: Constructor threw exception; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
	at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1315)
	... 192 more
Caused by: javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
	at javax.xml.stream.FactoryFinder.find(FactoryFinder.java:324)
	at javax.xml.stream.XMLOutputFactory.newFactory(XMLOutputFactory.java:263)
	at com.fasterxml.jackson.dataformat.xml.XmlFactory.<init>(XmlFactory.java:124)
	at com.fasterxml.jackson.dataformat.xml.XmlFactory.<init>(XmlFactory.java:101)
	at com.fasterxml.jackson.dataformat.xml.XmlFactory.<init>(XmlFactory.java:92)
	at com.fasterxml.jackson.dataformat.xml.XmlMapper.<init>(XmlMapper.java:141)
	at org.springframework.http.converter.json.Jackson2ObjectMapperBuilder$XmlObjectMapperInitializer.create(Jackson2ObjectMapperBuilder.java:888)
	at org.springframework.http.converter.json.Jackson2ObjectMapperBuilder.build(Jackson2ObjectMapperBuilder.java:647)
	at org.springframework.http.converter.xml.MappingJackson2XmlHttpMessageConverter.<init>(MappingJackson2XmlHttpMessageConverter.java:52)
	at org.springframework.http.converter.support.AllEncompassingFormHttpMessageConverter.<init>(AllEncompassingFormHttpMessageConverter.java:86)
	at org.springframework.web.client.RestTemplate.<init>(RestTemplate.java:145)
	at org.springframework.security.oauth2.provider.token.RemoteTokenServices.<init>(RemoteTokenServices.java:64)
	at org.geoserver.security.oauth2.GeoServerOAuthRemoteTokenServices.<init>(GeoServerOAuthRemoteTokenServices.java:54)
	at org.geoserver.security.oauth2.services.OpenIdConnectTokenServices.<init>(OpenIdConnectTokenServices.java:27)
	at sun.reflect.GeneratedConstructorAccessor691.newInstance(Unknown Source)
	... 194 more
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100198-sha1:e4e2d96)
Atlassian logo
