[Geoserver-devel] [JIRA] (GEOS-10512) Default KeystoreProviderImpl type is not FIPS-compliant (JCEKS)
Trae Yelovich created an issue
GeoServer / BugGEOS-10512
Issue Type:
BugBug
Affects Versions:
2.18.6, 2.20.4, 2.21.0
Assignee:
Unassigned
Created:
25/May/22 3:12 PM
Environment:
A FIPS-enabled Linux server w/ an OpenJDK 11 container (1.11)
Priority:
HighHigh
Reporter:
Trae Yelovich
The default keystore type for KeystoreProviderImpl is JCEKS. During startup, GeoServer tries to create a blank JCEKS keystore, or load an existing one within the data directory. However, in FIPS environments, a NoSuchAlgorithmException is thrown as JCEKS is not available under FIPS. As a result, we cannot get GeoServer to finish booting as FIPS mode is required and GeoServer depends on JCEKS to continue execution.
We’ve considered creating a compatible keystore provider as a workaround and importing it somehow - But, extension documentation seems scarce, especially regarding a custom keystore provider.
Ideally, a FIPS-compatible algorithm as the default keystore type would solve this issue. Another potential alternative would be to allow the system to provide a keystore type as an environment variable, and then default to JCEKS if the variable doesn’t exist.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100198-sha1:3aa2ccf)
Atlassian logo
