[Geoserver-devel] [JIRA] (GEOS-10516) WMS GetCapabilities dimension representations ignores the end attribute
Steve Ikeoka created an issue
GeoServer / BugGEOS-10516
Issue Type:
BugBug
Affects Versions:
2.20.4, 2.21.0
Assignee:
Unassigned
Components:
WMS
Created:
26/May/22 6:23 PM
Priority:
MediumMedium
Reporter:
Steve Ikeoka
Original post from mailing list:
> I have a feature based off a database table that I’m trying to add a Time Dimension with the “Attribute” and “End Attribute” set
> The Presentation is ‘Interval and Resolution’
> The Resolution is ‘5 minutes’
> The Default value is the ‘domain nearest to the reference value’
> The Reference Value is the ‘current’
> I can see the time dimension added to the getCapailbities “2022-05-19T17:50:00.000Z/2022-05-19T19:55:00.000Z/PT5M”
> The issue is the max value for End Attribute is "2022-05-19T23:38:00.000Z " why is the getCapabilities not displaying “2022-05-19T23:38:00.000Z” as the max interval? I see that the “end attribute” is only valid for a vector. Is a vector not any feature?
> If I change ‘Attribute’ to the ‘End Attribute’ value I can see it.
> <Dimension name=“time” default=“current” units=“ISO8601”>2022-05-19T20:55:00.000Z/2022-05-19T23:38:00.000Z/PT5M</Dimension>
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100198-sha1:963b379)
Atlassian logo
