[Geoserver-devel] [JIRA] (GEOS-10554) ImageMosaic plugin layer if deleted, deletes whole database
Alessio Fabiani created an issue
GeoServer / BugGEOS-10554
Issue Type:
BugBug
Assignee:
Unassigned
Created:
20/Jun/22 11:00 AM
Priority:
MediumMedium
Reporter:
Alessio Fabiani
Accordingly to this methos here it looks like a drop call to the ImageMosaic store will end up dropping the whole DB.
E.g.: a rest call like this <[http://localhost:8080/geoserver/rest/workspaces/geonode/coveragestores/optimized.xml?purge=all&recurse=true](http://localhost:8080/geoserver/rest/workspaces/geonode/coveragestores/optimized.xml?purge=all&recurse=true)> will force the plugin to DROP the whole DB defined into the datastore.properties file
This might be a big issue whenever we are going to use the same DB to store more than one dataset. In this specific case we will end up dropping all the data withing a single rest call.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100201-sha1:07cea57)
Atlassian logo
