[Geoserver-devel] [JIRA] (GEOS-10593) Creating SQL View via REST API is not possible
Matthias Heuser created an issue
GeoServer / BugGEOS-10593
Issue Type:
BugBug
Affects Versions:
2.21.0
Assignee:
Unassigned
Components:
REST
Created:
21/Jul/22 2:31 PM
Priority:
MediumMedium
Reporter:
Matthias Heuser
I am trying to create a layer by adding a feature type via the REST API that is using a virtual table (SQL View).
In the past (version 2.20.x) this worked without issue, but after the upgrade to 2.21.0 the creation fails with the following error:
Failed to access data source to check attribute customization
I then tried to add the layer manually to see if this still works and I was able to add this layer.
Further investigation of the changes between saving via the web application and saving via REST showed the following:
  • saving via web creates a virtual table entry in the JDBCDataSource
  • saving via REST does not create this virtual table entry in the data source
  • a new validation for FeatureTypeInfo (the FeatureTypeValidator) was introduced in 2.21.x
  • this validation fails because the virtual table entry is missing in the data source and there is no database table matching the native name of feature type I am trying to create.
When I added the virtual table entry (using a debugger) in the data source before the validation happens, the saving of the feature type was able to continue successfully.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100202-sha1:c075b5d)
Atlassian logo
