[Geoserver-devel] [JIRA] (GEOS-10670) SLD with one Rule not displaying Name/title in the legend
Karsten D. created an issue
GeoServer / BugGEOS-10670
Issue Type:
BugBug
Affects Versions:
2.20.4
Assignee:
Unassigned
Components:
styling
Created:
22/Sep/22 11:28 AM
Environment:
Windows Server 2019
Tomcat 9.0.62
Priority:
MediumMedium
Reporter:
Karsten D.
We are having a problem with styles where there only are one Rule, the Legend is not rendered with the Name/Title of the Rule. The capabilities dokument does not contain information for the LEGEND_OPTIONS described in the Geoserver Documentation, you cannot expect the client to know to set this option if the infomation is not avariable via the the capabilities dokument. Thereby must this be an error.
The expertation is that the Legend is rendered as its is displayed when you are creating and reviewing you style in Geoserver, but it simply does not show up as expected when you see the added style on the layer and if you request the legend from the link given in the capabilities dokument.
An example is below:
The only other way to get around this, is to make an “work around” by adding an empty rule, but this can give other problems, like timeouts if you go to a large schale, and not setting an MaxScaleDenominator to for example 1.
Best regards
Karsten
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100207-sha1:a65942b)
Atlassian logo
