[Geoserver-devel] [JIRA] (GEOS-10675) Missing JNA jar in GeoServer 2.21.1
Gael Lafond created an issue
GeoServer / BugGEOS-10675
Issue Type:
BugBug
Affects Versions:
2.21.1
Assignee:
Unassigned
Created:
27/Sep/22 8:55 AM
Environment:
OS: Ubuntu 20.04.5 LTS
Java: openjdk 11.0.16 2022-07-19
Tomcat: Apache Tomcat/9.0.31 (Ubuntu)
Priority:
HighestHighest
Reporter:
Gael Lafond
Can’t deploy GeoServer 2.21.1 (fresh install)
The issue is not present in GeoServer 2.21.0
Logs, when deploying the webapp in Tomcat:
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [config.XMLConfiguration] - Initializing GridSets from gwc
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [config.XMLConfiguration] - Initializing layers from gwc
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [gwc.layer] - GeoServer TileLayer store base directory is: gwc-layers
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [gwc.layer] - Loading tile layers from gwc-layers
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [gwc.layer] - Loaded 0 tile layers in 3.555 ms
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [storage.BlobStoreAggregator] - BlobStoreConfiguration gwc contained no blob store infos.
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [storage.DefaultStorageFinder] - Reverting to java.io.tmpdir ‘/tmp/geowebcache’ for storage. Please set GEOWEBCACHE_CACHE_DIR.
Sep 27 16:44:26 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:26 CONFIG [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:28 WARN [support.XmlWebApplicationContext] - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘monitorRest’: Unsatisfied dependency expressed through field ‘systemInfoCollector’; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘OSHISystemInfoCollector’ defined in URL [jar:file:/var/lib/tomcat9/webapps/geoserver/WEB-INF/lib/gs-main-2.21.1.jar!/org/geoserver/system/status/OSHISystemInfoCollector.class]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.system.status.OSHISystemInfoCollector]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: Could not initialize class com.sun.jna.Native
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:28 WARN [support.DisposableBeanAdapter] - Destroy method ‘destroy’ on bean with name ‘gwcMemoryBlobStore’ threw an exception: java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@anonymised.com[Not completed, task = org.geowebcache.storage.blobstore.memory.MemoryBlobStore$BlobStoreTask@anonymised.com] rejected from java.util.concurrent.ThreadPoolExecutor@anonymised.com[Shutting down, pool size = 1, active threads = 1, queued tasks = 0, completed tasks = 0]
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:28 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘metaTileCache’: Singleton bean creation not allowed while singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:28 ERROR [context.ContextLoader] - Context initialization failed
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘monitorRest’: Unsatisfied dependency expressed through field ‘systemInfoCollector’; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘OSHISystemInfoCollector’ defined in URL [jar:file:/var/lib/tomcat9/webapps/geoserver/WEB-INF/lib/gs-main-2.21.1.jar!/org/geoserver/system/status/OSHISystemInfoCollector.class]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.system.status.OSHISystemInfoCollector]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: Could not initialize class com.sun.jna.Native
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.resolveFieldValue(AutowiredAnnotationBeanPostProcessor.java:660)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:640)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:119)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessProperties(AutowiredAnnotationBeanPostProcessor.java:399)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1425)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:593)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:516)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:324)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:322)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:897)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:879)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:551)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:401)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:292)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4685)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5146)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:717)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:977)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1848)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:772)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:427)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1619)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:305)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase.backgroundProcess(ContainerBase.java:1151)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1353)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1357)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.run(ContainerBase.java:1335)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.lang.Thread.run(Thread.java:829)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘OSHISystemInfoCollector’ defined in URL [jar:file:/var/lib/tomcat9/webapps/geoserver/WEB-INF/lib/gs-main-2.21.1.jar!/org/geoserver/system/status/OSHISystemInfoCollector.class]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.system.status.OSHISystemInfoCollector]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: Could not initialize class com.sun.jna.Native
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1323)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1218)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:556)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.config.DependencyDescriptor.resolveCandidate(DependencyDescriptor.java:276)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:1307)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:1227)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.resolveFieldValue(AutowiredAnnotationBeanPostProcessor.java:657)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: … 45 more
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: Caused by: org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.system.status.OSHISystemInfoCollector]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: Could not initialize class com.sun.jna.Native
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:220)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1315)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: … 56 more
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: Caused by: java.lang.NoClassDefFoundError: Could not initialize class com.sun.jna.Native
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at com.sun.jna.NativeLong.<clinit>(NativeLong.java:35)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at oshi.util.FileUtil.readNativeLongFromBuffer(FileUtil.java:240)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at oshi.driver.linux.proc.Auxv.queryAuxv(Auxv.java:59)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at oshi.software.os.linux.LinuxOperatingSystem.<clinit>(LinuxOperatingSystem.java:106)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at oshi.SystemInfo.createOperatingSystem(SystemInfo.java:106)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at oshi.util.Memoizer$1.get(Memoizer.java:87)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at oshi.SystemInfo.getOperatingSystem(SystemInfo.java:98)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.geoserver.system.status.OSHISystemInfoCollector.<init>(OSHISystemInfoCollector.java:60)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:207)
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: … 58 more
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: One or more listeners failed to start. Full details will be found in the appropriate container log file
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: Context [/geoserver] startup failed due to previous errors
Sep 27 16:44:28 tsv-sc-geoserver tomcat9[2967]: 27 044 16:44:28 INFO [geoserver.logging] - Beginning GeoServer cleanup sequence
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: The web application [geoserver] appears to have started a thread named [FileSystemWatcher-1] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/jdk.internal.misc.Unsafe.park(Native Method)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:234)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2123)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@…7796…/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1182)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:899)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1054)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1114)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com…/java.lang.Thread.run(Thread.java:829)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: The web application [geoserver] appears to have started a thread named [EMF Reference Cleaner] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.lang.Object.wait(Native Method)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:155)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.base@anonymised.com/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:176)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: org.eclipse.emf.common.util.CommonUtil$1ReferenceClearingQueuePollingThread.run(CommonUtil.java:70)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: Failed to clear soft references from ObjectStreamClass$Caches for web application [geoserver]
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: java.lang.ClassCastException: class java.io.ObjectStreamClass$Caches$1 cannot be cast to class java.util.Map (java.io.ObjectStreamClass$Caches$1 and java.util.Map are in module java.base of loader ‘bootstrap’)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappClassLoaderBase.clearCache(WebappClassLoaderBase.java:2269)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesObjectStreamClassCaches(WebappClassLoaderBase.java:2256)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappClassLoaderBase.clearReferences(WebappClassLoaderBase.java:1627)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappClassLoaderBase.stop(WebappClassLoaderBase.java:1555)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappLoader.stopInternal(WebappLoader.java:443)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:257)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5432)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:187)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:717)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:705)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:977)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1848)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:772)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:427)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1619)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:305)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase.backgroundProcess(ContainerBase.java:1151)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1353)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1357)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.run(ContainerBase.java:1335)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: at java.base/java.lang.Thread.run(Thread.java:829)
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: The web application [geoserver] created a ThreadLocal with key of type [java.lang.ThreadLocal.SuppliedThreadLocal] (value [java.lang.ThreadLocal$SuppliedThreadLocal@anonymised.com]) and a value of type [org.geowebcache.storage.CompositeBlobStore.StoreSuitabilityCheck] (value [EXISTING]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: The web application [geoserver] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@anonymised.com]) and a value of type [org.geotools.referencing.operation.projection.TransverseMercator.Provider] (value [PROJECTION[“Transverse_Mercator”]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: The web application [geoserver] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@anonymised.com]) and a value of type [org.geotools.referencing.wkt.Formatter] (value ) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Sep 27 16:44:29 tsv-sc-geoserver tomcat9[2967]: Deployment of web application archive [/var/lib/tomcat9/webapps/geoserver.war] has finished in [13,575] ms
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: Illegal access: this web application instance has been stopped already. Could not load [org.geoserver.platform.resource.ResourceNotification$Kind]. The following stack trace is thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access.
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: java.lang.IllegalStateException: Illegal access: this web application instance has been stopped already. Could not load [org.geoserver.platform.resource.ResourceNotification$Kind]. The following stack trace is thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access.
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappClassLoaderBase.checkStateForResourceLoading(WebappClassLoaderBase.java:1385)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappClassLoaderBase.checkStateForClassLoading(WebappClassLoaderBase.java:1373)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1226)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1188)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at org.geoserver.platform.resource.FileSystemWatcher$Watch.pollDirectory(FileSystemWatcher.java:221)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at org.geoserver.platform.resource.FileSystemWatcher$Watch.changed(FileSystemWatcher.java:211)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at org.geoserver.platform.resource.FileSystemWatcher$1.run(FileSystemWatcher.java:342)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
Sep 27 16:44:31 tsv-sc-geoserver tomcat9[2967]: at java.base/java.lang.Thread.run(Thread.java:829)
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100207-sha1:520255c)
Atlassian logo
