Startup is mostly using CONFIG logging message now, but there are a few WARN and INFO messages that can be cleaned up.
- CONFIG is used for GeoServer configuration, even if it is configured by defaults from an empty GEOSERVER_DATA_DIR
- Save WARN for topics that user can address rather than expected functionality of GeoServer.
- Usual message when trying to configure without logging.xml - I would like this to be quite if it is expected
11:00:54 CONFIG [geoserver.logging] - Logging policy: Log4J2
11:00:54 ERROR [geoserver.logging] - Could not reconfigure LOG4J loggers
com.thoughtworks.xstream.io.StreamException:
at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:126)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readRealEvent(AbstractPullReader.java:148)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readEvent(AbstractPullReader.java:141)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.move(AbstractPullReader.java:118)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.moveDown(AbstractPullReader.java:103)
at com.thoughtworks.xstream.io.xml.XppReader.<init>(XppReader.java:63)
at com.thoughtworks.xstream.io.xml.AbstractXppDriver.createReader(AbstractXppDriver.java:54)
at com.thoughtworks.xstream.io.xml.AbstractXppDriver.createReader(AbstractXppDriver.java:65)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1293)
at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:715)
at org.geoserver.logging.LoggingStartupContextListener.getLogging(LoggingStartupContextListener.java:118)
- gce.imagemosaic warning about geotiff - can this be fixed in imageio-ext?
11:01:02 WARN [gce.imagemosaic] - Unable to set ordering between tiff readers spi
- Usual warnings from empty security folder. Not sure where accessDenied.jsp comes from?
11:01:03 WARN [geoserver.security] - Cannot find: /accessDenied.jsp
