Dieter Stüken created an issue |
Issue Type: |
Improvement |
Assignee: |
Unassigned |
Components: |
Main |
Created: |
12/Oct/22 7:08 PM |
Environment: |
Geoserver startup |
Priority: |
Medium |
Reporter: |
While reading its configuration various config.xml files are located as a Resource
and then parsed by XStreamPersister.load(r.in())
. If the resource does not exist calling Resource.in()
turns the missing resource into an empty file. This causes successive exceptions.
One of these cases was addressed by GEOS-10694, but I think this is a general problem here.
I find several locations, where a configuration is loaded from a resource. Some are testing if the resource exists, others don’t.
try/catch |
none |
if/else |
if/else |
throws IOException |
To handle these cases consistently I suggest introducing a general method
public <T> T load(Resource res, Class<T> clazz) throws IOException
to handle missing files either by returning null (which is handled correctly in most cases) or throwing a FileNotFoundException
(which again leads to confusing catch/try blocks again).
There are many other (61) examples where Resource.in()
is called unchecked or handled by complicated catch/try blocks, like in:
JDBCConfigurationStorage.getJDBCDiskQuotaConfig()
IMHO: I can’t figure out any situation, where creating an empty input file really makes sense to me. Instead, some Exception should be thrown. Looking at FileSystemResourceStore.in() I think this was indeed intended. However, using File actualFile = file()
already creates the file unintentionally. Using this.file
instead should restore the expected behavior and also leads to a more consistent stack trace. (I would rather suggest UncheckedIOException
instead of IllegalStateException
I even think about introducing some Optional<T>
to replace lots of those try/catch and if/else monsters by something simpler like:
resource.tryLoad(someLoader::load).orElse(someDefault)
Unfortunately, most of the load()
functions throw checked exceptions .
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100208-sha1:399748d) |
