[Geoserver-devel] [JIRA] (GEOS-10803) Geoserver :2.21.2 - Not able to start with the gsr-plugin
shailesh.gavathe created an issue
GeoServer / WishGEOS-10803
Issue Type:
WishWish
Affects Versions:
2.21.2
Assignee:
Unassigned
Components:
Configuration
Created:
19/Dec/22 6:57 PM
Environment:
docker.io/kartoza/geoserver:2.21.2
docker-compose -f docker-compose-build.yml up -d --build
COMMUNITY_EXTENSIONS=gsr-plugin
Priority:
MediumMedium
Reporter:
shailesh.gavathe
I get the below error. I know its a community plugin. But I was wondering, whom do I contact or where do I fix it ?
Error creating bean with name 'gsrDispatcher' defined in URL [jar:file:/usr/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-gsr-2.21-SNAPSHOT.jar!/applicationContext.xml]:
19 Dec 15:30:05 WARN [support.XmlWebApplicationContext] - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gsrDispatcher’ defined in URL [jar:file:/usr/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-gsr-2.21-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
19 Dec 15:30:05 INFO [jdbc.JDBCQuotaStore] - Closing up the JDBC quota store
19 Dec 15:30:05 WARN [support.DisposableBeanAdapter] - Destroy method ‘destroy’ on bean with name ‘gwcMemoryBlobStore’ threw an exception: java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@anonymised.com[Not completed, task = org.geowebcache.storage.blobstore.memory.MemoryBlobStore$BlobStoreTask@anonymised.com] rejected from java.util.concurrent.ThreadPoolExecutor@anonymised.com[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 1]
19 Dec 15:30:05 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘wmsLifecycleHandler’: Singleton bean creation not allowed while singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
19 Dec 15:30:05 ERROR [context.ContextLoader] - Context initialization failed
19-Dec-2022 15:30:05.344 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:602)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:516)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:324)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:322)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:202)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:897)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:879)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:551)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:401)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:292)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:103)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:22)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4768)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5230)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:726)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:698)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:696)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1185)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1933)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1095)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:477)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1618)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:319)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:946)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:835)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1396)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1386)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:919)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:265)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:432)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:930)
at org.apache.catalina.startup.Catalina.start(Catalina.java:772)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:476)
Caused by: javax.xml.stream.FactoryConfigurationError: Provider for javax.xml.stream.XMLOutputFactory cannot be found
at java.xml/javax.xml.stream.FactoryFinder.find(FactoryFinder.java:320)
at java.xml/javax.xml.stream.XMLOutputFactory.newFactory(XMLOutputFactory.java:299)
at com.fasterxml.jackson.dataformat.xml.XmlFactory.(XmlFactory.java:124)
at com.fasterxml.jackson.dataformat.xml.XmlFactory.(XmlFactory.java:101)
at com.fasterxml.jackson.dataformat.xml.XmlFactory.(XmlFactory.java:92)
at com.fasterxml.jackson.dataformat.xml.XmlMapper.(XmlMapper.java:141)
at org.springframework.http.converter.json.Jackson2ObjectMapperBuilder$XmlObjectMapperInitializer.create(Jackson2ObjectMapperBuilder.java:888)
at org.springframework.http.converter.json.Jackson2ObjectMapperBuilder.build(Jackson2ObjectMapperBuilder.java:647)
at org.springframework.http.converter.xml.MappingJackson2XmlHttpMessageConverter.(MappingJackson2XmlHttpMessageConverter.java:52)
at org.springframework.http.converter.support.AllEncompassingFormHttpMessageConverter.(AllEncompassingFormHttpMessageConverter.java:86)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.(RequestMappingHandlerAdapter.java:204)
at org.geoserver.ogcapi.APIConfigurationSupport$APIRequestMappingHandlerAdapter.(APIConfigurationSupport.java:35)
at org.geoserver.ogcapi.APIConfigurationSupport.createRequestMappingHandlerAdapter(APIConfigurationSupport.java:82)
at org.springframework.web.servlet.config.annotation.WebMvcConfigurationSupport.requestMappingHandlerAdapter(WebMvcConfigurationSupport.java:613)
at org.geoserver.ogcapi.APIDispatcher.initApplicationContext(APIDispatcher.java:138)
at org.springframework.context.support.ApplicationObjectSupport.setApplicationContext(ApplicationObjectSupport.java:78)
at org.springframework.context.support.ApplicationContextAwareProcessor.invokeAwareInterfaces(ApplicationContextAwareProcessor.java:123)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:100)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:415)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1791)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:594)
… 53 more
19-Dec-2022 15:30:05.345 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Context [/geoserver] startup failed due to previous errors
19 Dec 15:30:05 INFO [geoserver.logging] - Beginning GeoServer cleanup sequence
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.hsqldb.persist.RAFileNIO (file:/usr/local/tomcat/webapps/geoserver/WEB-INF/lib/hsqldb-2.4.1.jar) to method java.nio.DirectByteBuffer.cleaner()
WARNING: Please consider reporting this to the maintainers of org.hsqldb.persist.RAFileNIO
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
19-Dec-2022 15:30:06.509 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [geoserver] appears to have started a thread named [JNA Cleaner] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
java.base@anonymised.com/java.lang.Object.wait(Native Method)
java.base@anonymised.com/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:155)
java.base@anonymised.com/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:176)
com.sun.jna.internal.Cleaner$1.run(Cleaner.java:58)
19-Dec-2022 15:30:06.510 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [geoserver] appears to have started a thread named [FileSystemWatcher-1] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
java.base@anonymised.com/jdk.internal.misc.Unsafe.park(Native Method)
java.base@anonymised.com/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:234)
java.base@anonymised.com/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2123)
java.base@anonymised.com/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1182)
java.base@anonymised.com/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:899)
java.base@anonymised.com/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1054)
java.base@anonymised.com7796…/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1114)
java.base@anonymised.com/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
java.base@anonymised.com/java.lang.Thread.run(Thread.java:829)
19-Dec-2022 15:30:06.531 WARNING [main] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [geoserver] appears to have started a thread named [Timer-0] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
java.base@anonymised.com/java.util.TimerThread.mainLoop(Timer.java:553)
java.base@anonymised.com/java.util.TimerThread.run(Timer.java:506)
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100212-sha1:9b20a48)
Atlassian logo
