[Geoserver-devel] [JIRA] (GEOS-10805) Getting IpAddressMatcher.parseAddress issue when proxy is used as more than one IP is passed
Goutaam T created an issue
GeoServer / BugGEOS-10805
Issue Type:
BugBug
Assignee:
Unassigned
Components:
Security
Created:
21/Dec/22 1:15 PM
Environment:
Geoserver 2.22.0 hosted on Azure App Service with Spring Cloud Proxy in front.
Priority:
MediumMedium
Reporter:
Goutaam T
When user requests data from GeoServer, proxy chaining is observed in the request headers.
Eg: x-forwarded-for: 1.1.1.1, 2.2.2.2 (original IPs masked).
By default, Brute Force Prevention is enabled in GeoServer and it uses the entire string from the x-forwarded-for request header to validate via Spring Security which contains two IPs. We’re getting the below error:
java.lang.IllegalArgumentException: Failed to parse address1.1.1.1, 2.2.2.2
at org.springframework.security.web.util.matcher.IpAddressMatcher.parseAddress(IpAddressMatcher.java:107)
at org.springframework.security.web.util.matcher.IpAddressMatcher.matches(IpAddressMatcher.java:66)
at org.springframework.security.web.util.matcher.IpAddressMatcher.matches(IpAddressMatcher.java:62)
at org.geoserver.security.BruteForceListener.lambda$requestAddressInWhiteList$0(BruteForceListener.java:125)
at java.base/java.util.stream.MatchOps$1MatchSink.accept(MatchOps.java:90)
at java.base/java.util.ArrayList$ArrayListSpliterator.tryAdvance(ArrayList.java:1632)
at java.base/java.util.stream.ReferencePipeline.forEachWithCancel(ReferencePipeline.java:127)
at java.base/java.util.stream.AbstractPipeline.copyIntoWithCancel(AbstractPipeline.java:502)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:488)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.MatchOps$MatchOp.evaluateSequential(MatchOps.java:230)
at java.base/java.util.stream.MatchOps$MatchOp.evaluateSequential(MatchOps.java:196)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.anyMatch(ReferencePipeline.java:528)
at org.geoserver.security.BruteForceListener.requestAddressInWhiteList(BruteForceListener.java:125)
at org.geoserver.security.BruteForceListener.onApplicationEvent(BruteForceListener.java:65)
at org.geoserver.security.BruteForceListener.onApplicationEvent(BruteForceListener.java:28)
at org.springframework.context.event.SimpleApplicationEventMulticaster.doInvokeListener(SimpleApplicationEventMulticaster.java:172)
at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:165)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:139)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:404)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:361)
at org.springframework.security.authentication.DefaultAuthenticationEventPublisher.publishAuthenticationSuccess(DefaultAuthenticationEventPublisher.java:99)
at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:224)
at org.geoserver.security.GeoServerSecurityManager$1.authenticate(GeoServerSecurityManager.java:314)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:180)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at com.microsoft.azure.appservice.filters.AppServiceFilter.doFilter(AppServiceFilter.java:59)
at com.microsoft.azure.appservice.EasyAuthFilter.doFilter(EasyAuthFilter.java:42)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:687)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:360)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:399)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:890)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1743)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.net.UnknownHostException: 1.1.1.1, 2.2.2.2
at java.base/java.net.InetAddress$CachedAddresses.get(InetAddress.java:797)
at java.base/java.net.InetAddress.getAllByName0(InetAddress.java:1509)
at java.base/java.net.InetAddress.getAllByName(InetAddress.java:1368)
at java.base/java.net.InetAddress.getAllByName(InetAddress.java:1302)
at java.base/java.net.InetAddress.getByName(InetAddress.java:1252)
at org.springframework.security.web.util.matcher.IpAddressMatcher.parseAddress(IpAddressMatcher.java:104)
… 82 more
On disabling the Brute Force Prevention, it is working.
We observed the entire IP string from the request header is passed while the Spring Security methods expect a single IP for the hostname check.
Should GeoServer Brute Force Prevention take only the source IP (1.1.1.1) instead of considering the entire IPs string (1.1.1.1, 2.2.2.2) ?
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100213-sha1:d1b903b)
Atlassian logo
