Type Exception Report
Message Error occurred while reading configuration file ‘/geoserver/printing/config.yaml’: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘mapPrinter’: Unsatisfied dependency expressed through field ‘configFactory’; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘configFactory’: Unsatisfied dependency expressed through field ‘threadResources’; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘threadResources’: Lookup method resolution failed; nested exception is java.lang.IllegalStateException: Failed to introspect Class [org.mapfish.print.ThreadResources] from ClassLoader [ParallelWebappClassLoader
Description The server encountered an unexpected condition that prevented it from fulfilling the request.
Exception
javax.servlet.ServletException: Error occurred while reading configuration file ‘/geoserver/printing/config.yaml’: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘mapPrinter’: Unsatisfied dependency expressed through field ‘configFactory’; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name ‘configFactory’: Unsatisfied dependency expressed through field ‘threadResources’; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘threadResources’: Lookup method resolution failed; nested exception is java.lang.IllegalStateException: Failed to introspect Class [org.mapfish.print.ThreadResources] from ClassLoader [ParallelWebappClassLoader
context: geoserver
delegate: false
----------> Parent Classloader:
java.net.URLClassLoader@anonymised.com
org.mapfish.print.servlet.BaseMapServlet.getMapPrinter(BaseMapServlet.java:144)
org.mapfish.print.servlet.MapPrinterServlet.getInfo(MapPrinterServlet.java:279)
org.mapfish.print.servlet.MapPrinterServlet.doGet(MapPrinterServlet.java:99)
javax.servlet.http.HttpServlet.service(HttpServlet.java:670)
javax.servlet.http.HttpServlet.service(HttpServlet.java:779)
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:166)
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:52)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1043)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:356)
org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:175)
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:73)
org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:194)
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:43)
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
Note The full stack trace of the root cause is available in the server logs.
Apache Tomcat/9.0.70
