Ian Turton created an issue |
Importer doesn’t provide a way to set SSL on/off etc in postgis connection |
Issue Type: |
Bug |
Affects Versions: |
2.21.0, 2.22.0 |
Assignee: |
Unassigned |
Components: |
Importer |
Created: |
13/Jan/23 3:59 PM |
Priority: |
Medium |
Reporter: |
If you have set up your postgis db to require SSL connections then you can’t use the importer extension to import data as it is not possible to change the SSL connection setting as it is with the normal PostGIS datastore. Workaround - allow insecure logins to the database. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100214-sha1:b03f6a4) |
