[Geoserver-devel] [JIRA] (GEOS-10828) OGC API - Features - Plugin breaks core `/rest` API with JSON payloads
Sebastian Frey created an issue
GeoServer / BugGEOS-10828
OGC API - Features - Plugin breaks core /rest API with JSON payloads
Issue Type:
BugBug
Assignee:
Unassigned
Created:
17/Jan/23 2:44 PM
Priority:
MediumMedium
Reporter:
Sebastian Frey
When using the latest version of the OGC API plugin, the core /rest API breaks with JSON payloads. For example, than it is no longer possible to create a workspace by using a JSON payload.
Steps to reproduce:
  1. Download latest GeoServer WAR and latest OGC API plugin.
  2. Deploy it within Tomcat.
  3. Try to create a workspace as follows:
curl -v -u admin:geoserver -X POST \
  -H "Content-type: application/json" \
  -d '{"workspace":{"name":"test"}}' \
  http://localhost:8080/geoserver/rest/workspaces
Within the GeoServer logs you will find the following stack trace:
17 Jan 14:35:19 ERROR  [geoserver.rest] - Type definition error: [simple type, class org.geoserver.catalog.WorkspaceInfo]; nested exception is com.fasterxml.jackson.databind.exc.InvalidDefinitionException: Cannot construct instance of `org.geoserver.catalog.WorkspaceInfo` (no Creators, like default constructor, exist): abstract types either need to be mapped to concrete types, have custom deserializer, or contain additional type information
 at [Source: (PushbackInputStream); line: 1, column: 1]
org.springframework.http.converter.HttpMessageConversionException: Type definition error: [simple type, class org.geoserver.catalog.WorkspaceInfo]; nested exception is com.fasterxml.jackson.databind.exc.InvalidDefinitionException: Cannot construct instance of `org.geoserver.catalog.WorkspaceInfo` (no Creators, like default constructor, exist): abstract types either need to be mapped to concrete types, have custom deserializer, or contain additional type information
	at org.springframework.http.converter.json.AbstractJackson2HttpMessageConverter.readJavaType(AbstractJackson2HttpMessageConverter.java:282)
	at org.springframework.http.converter.json.AbstractJackson2HttpMessageConverter.read(AbstractJackson2HttpMessageConverter.java:243)
	at org.springframework.web.servlet.mvc.method.annotation.AbstractMessageConverterMethodArgumentResolver.readWithMessageConverters(AbstractMessageConverterMethodArgumentResolver.java:205)
	at org.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor.readWithMessageConverters(RequestResponseBodyMethodProcessor.java:158)
	at org.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor.resolveArgument(RequestResponseBodyMethodProcessor.java:131)
	at org.springframework.web.method.support.HandlerMethodArgumentResolverComposite.resolveArgument(HandlerMethodArgumentResolverComposite.java:121)
	at org.springframework.web.method.support.InvocableHandlerMethod.getMethodArgumentValues(InvocableHandlerMethod.java:167)
	at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:134)
	at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:105)
	at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:878)
	at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:792)
	... 93 more
Caused by: com.fasterxml.jackson.databind.exc.InvalidDefinitionException: Cannot construct instance of `org.geoserver.catalog.WorkspaceInfo` (no Creators, like default constructor, exist): abstract types either need to be mapped to concrete types, have custom deserializer, or contain additional type information
	at com.fasterxml.jackson.databind.exc.InvalidDefinitionException.from(InvalidDefinitionException.java:67)
	at com.fasterxml.jackson.databind.DeserializationContext.reportBadDefinition(DeserializationContext.java:1904)
	at com.fasterxml.jackson.databind.DatabindContext.reportBadDefinition(DatabindContext.java:400)
	at com.fasterxml.jackson.databind.DeserializationContext.handleMissingInstantiator(DeserializationContext.java:1349)
	at com.fasterxml.jackson.databind.deser.AbstractDeserializer.deserialize(AbstractDeserializer.java:274)
	at com.fasterxml.jackson.databind.deser.DefaultDeserializationContext.readRootValue(DefaultDeserializationContext.java:323)
	at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:4674)
	at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3682)
	at org.springframework.http.converter.json.AbstractJackson2HttpMessageConverter.readJavaType(AbstractJackson2HttpMessageConverter.java:274)
	... 104 more
On further investigations I have noticed that the OGC API plugin registers a custom MappingJackson2HttpMessageConverter:
https://github.com/geoserver/geoserver/blob/main/src/community/ogcapi/ogcapi-core/src/main/java/org/geoserver/ogcapi/APIDispatcher.java#L156
By commenting out this line, the core /rest API does not break and the above request works as expected.
Just an idea: It seems like that some Jackson mappers are lost from core, when the OGC API plugin registers the custom converter.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100214-sha1:771690a)
Atlassian logo
