[Geoserver-devel] [JIRA] (GEOS-10862) JAIExt registerOp and CoverageProcessor messages on startup
Jody Garnett created an issue
GeoServer / TaskGEOS-10862
Issue Type:
TaskTask
Affects Versions:
2.21.4
Assignee:
Unassigned
Components:
Main
Created:
16/Feb/23 1:15 AM
Priority:
MediumMedium
Reporter:
Jody Garnett
On startup GeoServer 2.21.x is producing warnings due to normal operation of JAI:
15 Feb. 16:08:38 WARN   [coverage.processing] - Operation: BandCombine not found in CoverageProcessor
15 Feb. 16:08:38 WARN   [coverage.processing] - Operation: BandSelect not found in CoverageProcessor
15 Feb. 16:08:38 WARN   [coverage.processing] - Operation: Binarize not found in CoverageProcessor
15 Feb. 16:08:38 WARN   [coverage.processing] - Operation: AndConst not found in CoverageProcessor
15 Feb. 16:08:38 WARN   [coverage.processing] - Operation: OrConst not found in CoverageProcessor
15 Feb. 16:08:38 WARN   [coverage.processing] - Operation: XorConst not found in CoverageProcessor
JAIExt registerOp produces a series of INFO messages which may or may not be necessary? Reducing these to CONFIG allow for a clean startup. These messages also include a linefeed (not sure why).
Feb. 15, 2023 4:08:38 P.M. it.geosolutions.jaiext.JAIExt registerOp
INFO: Registered operation: Affine
INFO: Registered operation: BandCombine
INFO: Unable to register the descriptor related to the following operation: Null
INFO: Registered operation: operationConst
One of the operations has a null descriptor, failing to register which should be a WARNING?
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100216-sha1:a1e7611)
Atlassian logo
