[Geoserver-devel] [JIRA] (GEOS-10906) Authentication not sent if connection pooling activated
Pierre Mauduit created an issue
GeoServer / BugGEOS-10906
Issue Type:
BugBug
Affects Versions:
2.22.2
Assignee:
Unassigned
Components:
WMS
Created:
24/Mar/23 3:33 PM
Environment:
Runtime tested into the [docker.osgeo.org/geoserver:2.22.2](http://docker.osgeo.org/geoserver:2.22.2) docker image
Priority:
MediumMedium
Reporter:
Pierre Mauduit
It seems that when trying to access a secured remote WMS with connection pooling activated, the basic-authentication is not sent. Indeed, while trying to add a Cascaded WMS datastore configured onto a protected WMS, along with a correct basic authentication, I got the following stacktrace server-side:
{code}
24 Mar 14:10:42 INFO [geoserver.web] - Getting list of layers for the WMS store https://protected-wms/mapproxy/service?
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: null
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:181)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:60)
at org.geoserver.web.wicket.GeoServerDataProvider.getFilteredItems(GeoServerDataProvider.java:190)
at org.geoserver.web.data.layer.NewLayerPageProvider.getFilteredItems(NewLayerPageProvider.java:197)
at org.geoserver.web.wicket.GeoServerDataProvider.size(GeoServerDataProvider.java:208)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:662)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.<init>(GeoServerTablePanel.java:657)
at org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:236)
at org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:105)
at org.geoserver.web.data.layer.NewLayerPage$1.<init>(NewLayerPage.java:111)
at org.geoserver.web.data.layer.NewLayerPage.<init>(NewLayerPage.java:110)
at org.geoserver.web.data.store.WMSStoreNewPage.onSave(WMSStoreNewPage.java:88)
at org.geoserver.web.data.store.AbstractWMSStorePage$2.onSubmit(AbstractWMSStorePage.java:212)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:111)
Caused by: java.io.IOException
at org.geoserver.catalog.ResourcePool.getWebMapServer(ResourcePool.java:1869)
at org.geoserver.catalog.impl.WMSStoreInfoImpl.getWebMapServer(WMSStoreInfoImpl.java:104)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144)
at com.sun.proxy.$Proxy126.getWebMapServer(Unknown Source)
at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:141)
… 138 more
Caused by: org.geotools.ows.ServiceException: Error while parsing XML.
org.xml.sax.SAXParseException; lineNumber: 28; columnNumber: 3; The element type “meta” must be terminated by the matching end-tag “</meta>”.
at org.geotools.ows.wms.response.WMSGetCapabilitiesResponse.<init>(WMSGetCapabilitiesResponse.java:58)
at org.geotools.ows.wms.WMS1_0_0$GetCapsRequest.createResponse(WMS1_0_0.java:230)
at org.geotools.data.ows.AbstractOpenWebService.internalIssueRequest(AbstractOpenWebService.java:461)
at org.geotools.ows.wms.WebMapServer.issueRequest(WebMapServer.java:450)
at org.geotools.data.ows.AbstractOpenWebService.negotiateVersion(AbstractOpenWebService.java:287)
at org.geotools.data.ows.AbstractOpenWebService.<init>(AbstractOpenWebService.java:124)
at org.geotools.data.ows.AbstractOpenWebService.<init>(AbstractOpenWebService.java:97)
at org.geotools.ows.wms.WebMapServer.<init>(WebMapServer.java:405)
at org.geoserver.catalog.ResourcePool.createWebMapServer(ResourcePool.java:1886)
at org.geoserver.catalog.ResourcePool.getWebMapServer(ResourcePool.java:1857)
… 146 more
Caused by: org.xml.sax.SAXParseException; lineNumber: 28; columnNumber: 3; The element type “meta” must be terminated by the matching end-tag “</meta>”.
at java.xml/com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:204)
at java.xml/com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:178)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:400)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1465)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1685)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2883)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:605)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:112)
at java.xml/com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:534)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:888)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:824)
at java.xml/com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1216)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:635)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:324)
at java.xml/javax.xml.parsers.SAXParser.parse(SAXParser.java:197)
at org.geotools.xml.DocumentFactory.getInstance(DocumentFactory.java:128)
at org.geotools.ows.wms.response.WMSGetCapabilitiesResponse.<init>(WMSGetCapabilitiesResponse.java:56)
… 155 more
{code}
I suspect the stacktrace to appear when GeoTools tries to parse a HTML page, being redirected onto the login page of the remote system, after a failing connection attempt.
If I deactivate the connection pooling when creating the datastore, I don’t encounter the issue, and I am able to publish a cascaded layer afterwards.
Using a publicly available remote WMS, I can create cascaded layers, no matter whether the connection pooling is activated or not.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100219-sha1:ac3e918)
Atlassian logo
