Gabriel Roldan created an issue |
Issue Type: |
New Feature |
Assignee: |
Created: |
29/Mar/23 6:16 PM |
Priority: |
Medium |
Reporter: |
Proposal: https://github.com/geoserver/geoserver/wiki/GSIP-217 GeoServer ACL is an advanced authorization system for GeoServer. It consists of an independent application service that manages access rules, and a GeoServer plugin that requests authorization limits on a per-request basis. As an administrator you’ll use GeoServer ACL to define rules that grant or deny access to published resources based on service request properties such user credentials, the type of OWS service, and layers being requested. These rules can be as open as to grant or deny access to whole GeoServer workspaces, or as granular as to specify which geographical areas and layer attributes to allow a specific user or user group to see. As a user you’ll perform requests to GeoServer such as WMS GetMap or WFS GetFeatures, and the ACL-based authorization engine will limit the visibility of the resources and contents of the responses to those matching the rules that apply to the request properties and the authenticated user credentials. GeoServer ACL is not an authentication provider. It’s an authorization manager that will use the authenticated user credentials, whether they come from Basic HTTP, OAuth2/OpenID Connect, or whatever authentication mechanism GeoServer is using, to resolve the access rules that apply to each particular request. GeoServer ACL is Open Source, born as a fork of GeoFence. As such, it follows the same logic to define data access and administrative access rules. So if you’re familiar with GeoFence, it’ll be easy to reason about GeoServer ACL. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100219-sha1:6a6077b) |
