[Geoserver-devel] [JIRA] (GEOS-11007) NullPointerException raised with WFS queries on database
Nicolas Vila created an issue
GeoServer / BugGEOS-11007
Issue Type:
BugBug
Affects Versions:
2.22.3
Assignee:
Unassigned
Erreur Geoserver.txt
Components:
WFS
Created:
01/Jun/23 4:25 PM
Environment:
  • GeoServer 2.22.0
  • Révision Git dbc9f525ed9f98d8ac5d128c1a765b8a37092f7d
  • Build Date 17-Nov-2022 18:23
  • GeoTools 28.0 (rev 93b0abe9bc755432862825e19306e8b8e7114c2d)
  • GeoWebCache 1.22.0 (rev 1.22.x/ba83cb90b873cb98b7f418f577a4ae8b3ec1adbf)
Priority:
MediumMedium
Reporter:
Nicolas Vila
I’m facing a strange issue while sending request on a database table with WFS.
What I find out:
  • Removing the paging make it works but can send back unwanted features.
  • If I let the paging, it crashes
  • If I let the paging and manually add “sortBy” parameter in the WFS query, it seems to work.
I suspect the issue to be related to the database. The table does not contain a Primary Key. Maybe sorting depends on the primary key? Please find enclosed the Geoserver log and stacktrace.
The issue occurs in this class, at org.geotools.data.transform.TransformFeatureCollection.openIterator(TransformFeatureCollection.java:130)
https://github.com/geotools/geotools/blob/27.x/modules/extension/transform/src/main/java/org/geotools/data/transform/TransformFeatureCollection.java
Regards.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100225-sha1:40c4da4)
Atlassian logo
