[Geoserver-devel] [JIRA] (GEOS-11013) Using metadata-plugin prevents geoserver-docker starting correctly
Markus Heber created an issue
GeoServer / BugGEOS-11013
Issue Type:
BugBug
Affects Versions:
2.23.1
Assignee:
Unassigned
Components:
website
Created:
05/Jun/23 2:25 PM
Environment:
The metadata-plugin seems to have a compatibility-issue with version 2.23 and if executed within docker.
OS: windows
Docker: 20.10.22
Image: docker.osgeo.org/geoserver:2.23.1 and docker.osgeo.org/geoserver:2.23.x
Priority:
MediumMedium
Reporter:
Markus Heber
If starting geoserver as docker by using
docker run -it -p8080:8080 --env INSTALL_EXTENSIONS=true --env STABLE_EXTENSIONS=“vectortiles,metadata” docker.osgeo.org/geoserver:2.23.1
the server crashes at startup with exception
java.lang.IllegalStateException: Illegal access: this web application instance has been stopped already. Could not load [java.util.concurrent.CompletableFuture].
If using the snapshot-version by running
docker run -it -p8080:8080 --env INSTALL_EXTENSIONS=true --env STABLE_EXTENSIONS=“vectortiles,metadata” docker.osgeo.org/geoserver:2.23.x
no crash is reported, but if I open the ui in browser (http://localhost:8080/geoserver), no ui is shown.
In both cases, if I omit the metadata-extension, everything works fine.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100225-sha1:4a1ccf9)
Atlassian logo
