[Geoserver-devel] [JIRA] (GEOS-11021) Clicking on a layer name corresponding to a deleted table in Wicket UI on 2.23.0 takes user to error page
Alex McMahon created an issue
GeoServer / BugGEOS-11021
Issue Type:
BugBug
Affects Versions:
2.23.0
Assignee:
Unassigned
Components:
Wicket UI
Created:
07/Jun/23 7:52 PM
Priority:
LowLow
Reporter:
Alex McMahon
I’ve published a bunch of layers to a PostGIS store and subsequently deleted the PostGIS tables they were published from on a 2.23.0 geoserver instance. When clicking on the layer name corresponding to a deleted table, I’m taken to an error page and get the stack trace below. The following shows up in the logs:
WARN [geoserver.catalog] - Unable to flush '<my-layername-here>
java.io.IOException: Schema ‘<my-layername-here>’ does not exist.
This is not the case in our 2.18.0 instance, where instead clicking on the deleted layer name still takes me to the edit layer menu for it and a warning banner with the following:
Failed to load attribute list, internal error is: Schema ‘<my-layername-here>’ does not exist.
Full stack trace from 2.23.0 instance:
org.apache.wicket.WicketRuntimeException: Failed to add pluggable resource configuration panels
at org.geoserver.web.data.resource.ResourceConfigurationPage$DataLayerEditTabPanel$1.populateItem(ResourceConfigurationPage.java:158)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
at org.apache.wicket.Component.internalBeforeRender(Component.java:950)
at org.apache.wicket.Component.beforeRender(Component.java:1018)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1826)
at org.apache.wicket.Component.onBeforeRender(Component.java:3921)
at org.apache.wicket.extensions.markup.html.tabs.TabbedPanel.onBeforeRender(TabbedPanel.java:274)
at org.apache.wicket.markup.html.form.Form.onBeforeRender(Form.java:1816)
at org.apache.wicket.Page.onBeforeRender(Page.java:801)
at org.apache.wicket.Component.internalPrepareForRender(Component.java:2236)
at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
at org.apache.wicket.Component.render(Component.java:2327)
at org.apache.wicket.Page.renderPage(Page.java:1018)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:502)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:596)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:166)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:51)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1072)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:965)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:209)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:153)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:178)
at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:328)
at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:158)
at org.apache.catalina.filters.HttpHeaderSecurityFilter.doFilter(HttpHeaderSecurityFilter.java:126)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:73)
at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:90)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.HTTPMethodFilter.doFilter(HTTPMethodFilter.java:36)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:194)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:89)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:43)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:337)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:115)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:81)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:346)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:122)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:116)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:223)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:217)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:122)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:106)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:97)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilterInternal(GeoServerSecurityContextPersistenceFilter.java:72)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:221)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:186)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:167)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:492)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:130)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:673)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:389)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:926)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1791)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.lang.reflect.InvocationTargetException
at jdk.internal.reflect.GeneratedConstructorAccessor267.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
at org.geoserver.web.data.resource.ResourceConfigurationPage$DataLayerEditTabPanel$1.populateItem(ResourceConfigurationPage.java:155)
… 156 more
Caused by: org.apache.wicket.WicketRuntimeException: No Page found for component [WebMarkupContainer [Component id = attributePanel]]
at org.apache.wicket.Component.getPage(Component.java:1757)
at org.geoserver.web.data.resource.AttributeTypeInfoEditor.loadNativeAttributes(AttributeTypeInfoEditor.java:132)
at org.geoserver.web.data.resource.AttributeTypeInfoEditor.getAttributes(AttributeTypeInfoEditor.java:99)
at org.geoserver.web.data.resource.AttributeTypeInfoEditor.<init>(AttributeTypeInfoEditor.java:85)
at org.geoserver.web.data.resource.FeatureResourceConfigurationPanel.<init>(FeatureResourceConfigurationPanel.java:93)
… 160 more
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100225-sha1:62413c2)
Atlassian logo
