Samo Dadela created an issue |
Issue Type: |
Bug |
Assignee: |
Unassigned |
Created: |
16/Jun/23 11:03 AM |
Priority: |
Medium |
Reporter: |
I wanted to compile/run geoserver locally (on Linux in IntelliJ IDEA) to troubleshoot GEOS-11028 Open . Followed the developer guide. When I try to start the app, I get compilation errors in the wcs1_1 module. First problem is a missing import for Node in AbstractContentNode. Since AbstractContentNode doesn’t seem to be used anywhere i tried to delete it. But the I get errors in RangeSubsetKeyParser.java. All those imports are unknown.
Tried to unload wcs1_1 but it seems it is a required module. I also tried to use branch 2.23.x but there are even more problems |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100227-sha1:5147d46) |
