[Geoserver-devel] [JIRA] (GEOS-11038) Geoserver 2.23.1 doesnt pick up web-fragment.xml within custom jar when deployed on WebLogic
Luke South created an issue
GeoServer / BugGEOS-11038
Issue Type:
BugBug
Affects Versions:
2.23.1
Assignee:
Unassigned
Components:
web-app
Created:
21/Jun/23 12:46 PM
Environment:
WebLogic 14.1.1
GeoServer 2.23.1
Priority:
LowLow
Reporter:
Luke South
We have a custom jar file that contains filters, a servlet, and a web-fagment.xml that are to be included alongside the deployment of GeoServer. Adding this jar to WEB-INF/lib is sufficient for a Tomcat 9 deployment, the jar is picked up, the customisations are executed when testing. However when deploying this same customised geoserver war to WebLogic, the custom servlet and filters are not getting executed.
I found that if i edited the web.xml file by replacing the first tag with the following to explicitly mention servlet version 3 the customisations are picked up and executed.
<web-app xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="http://java.sun.com/xml/ns/javaee"
xmlns:web="http://java.sun.com/xml/ns/javaee/web-app_3_0.xsd"
xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_3_0.xsd"
id="WebApp_ID" version="3.0">
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100227-sha1:28a616e)
Atlassian logo
