Hello ,
Testing the Geoserver OpenID Keycloak plugin. We have setup a filter to test it on a very simple aboutpage. But when I connect to about page, instead of redirecting it gives me 500 error. Not sure what this about ?
HTTP Status 500 – Internal Server Error
Type Exception Report
Message Unable to handle the Spring Security Exception because the response is already committed.
Description The server encountered an unexpected condition that prevented it from fulfilling the request.
Exception
javax.servlet.ServletException: Unable to handle the Spring Security Exception because the response is already committed.
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:139)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)
org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:122)
org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:166)
org.geoserver.security.filter.GeoServerRoleFilter.doFilter(GeoServerRoleFilter.java:54)
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
Root Cause
org.springframework.security.authentication.AuthenticationCredentialsNotFoundException: An Authentication object was not found in the SecurityContext
org.springframework.security.access.intercept.AbstractSecurityInterceptor.credentialsNotFound(AbstractSecurityInterceptor.java:379)
org.springframework.security.access.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:223)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:124)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
Note The full stack trace of the root cause is available in the server logs.
