Gabriel Roldan created an issue |
Issue Type: |
New Feature |
Assignee: |
Components: |
Community modules |
Created: |
01/Jul/23 4:36 PM |
Priority: |
Medium |
Reporter: |
There’s an optimized data-directory-specific catalog and config loader plugin developed under geoserver-cloud’s code base that we’d like to contribute upstream as a community module. Its goal is to improve the startup time of GeoServer when configured with a data directory that has thousands of layers, stores, etc., and config objects such as workspace services and settings. On my laptop’s SSD, running off a cold disk cache, for a data-dir with 100K layers over 100 workspaces, the performance improvement is ~8.5 seconds instead of ~44.5 seconds, with 2.23.1 as a baseline. But the most important difference is when you need to load the data dir from a shared drive, especially NFS, where it regularly takes over 40 minutes, and with this plugin around 4 minutes. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100227-sha1:9e449c4) |
