Peter Smythe created an issue |
ENV params not used correctly by AuthKey extension, thus overwritten |
Issue Type: |
Bug |
Affects Versions: |
2.22.2 |
Assignee: |
Unassigned |
Attachments: |
image-20230704-115043.png, image-20230704-115356.png, image-20230704-115727.png |
Components: |
authkey |
Created: |
04/Jul/23 2:00 PM |
Priority: |
Medium |
Reporter: |
https://docs.geoserver.org/latest/en/user/datadirectory/configtemplate.html can be used in other places, correctly e.g. Global Settings: saved in global.xml thus:
However, the Authkey extension https://docs.geoserver.org/latest/en/user/extensions/authkey/index.html does not work perfectly. The admin is able to enter the parameterised URL correctly: saved in data/security/filter/AuthKey Filter/config.xml correctly:
However, when the GUI loads it again, the substituted parameter is visible (this is the bug): and when saved, the config.xml file is exactly this substituted string, not the parameterised version:
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100228-sha1:4a42edc) |
