[Geoserver-devel] [JIRA] (GEOS-11052) Default config files do not indicate correctly how to setup the CORS filter
Robin KERDILES created an issue
GeoServer / BugGEOS-11052
Issue Type:
BugBug
Affects Versions:
2.22.5
Assignee:
Unassigned
Components:
Documentation
Created:
05/Jul/23 11:51 AM
Environment:
Geoserver container behind a reverse proxy which is terminating the connexion over TLS.
Headers are transmitted (X-Forwaded-*)
Priority:
LowLow
Reporter:
Robin KERDILES
The default file web.xml has a wrong order in the filters if we want to add CORS.
There is a conflict with spring security and the login is impossible unless I add the CORS filter as the last filter.
The first filter made me think that the order of the filters provided as a comment block for the CORS was important as well.
      THIS FILTER MAPPING MUST BE THE FIRST ONE, otherwise we end up with ruined chars in the input from the GUI
      See the "Note" in the Tomcat character encoding guide:
      http://wiki.apache.org/tomcat/FAQ/CharacterEncoding
    <filter-mapping>
      <filter-name>Set Character Encoding</filter-name>
      <url-pattern>/*</url-pattern>
    </filter-mapping>
   <!-- Uncomment following filter to enable CORS
    <filter-mapping>
        <filter-name>cross-origin</filter-name>
    </filter-mapping>
Here is the diff file with a working configuration for my specific environment
--- web.xml.orig
+++ web.xml
@@ -156,25 +156,31 @@
       </init-param>
     </filter>
-   <!-- Uncomment following filter to enable CORS in Tomcat. Do not forget the second config block further down.
     <filter>
-      <filter-name>cross-origin</filter-name>
+      <filter-name>DockerGeoServerCorsFilter</filter-name>
       <filter-class>org.apache.catalina.filters.CorsFilter</filter-class>
       <init-param>
-        <param-name>cors.allowed.origins</param-name>
-        <param-value>*</param-value>
+          <param-name>cors.allowed.origins</param-name>
+          <param-value>https://sequoia.aubepine.emanrisk.net,https://sequoia.chene.emanrisk.net,https://sequoia.maite.emanrisk.net</param-value>
       </init-param>
       <init-param>
-        <param-name>cors.allowed.methods</param-name>
-        <param-value>GET,POST,PUT,DELETE,HEAD,OPTIONS</param-value>
+          <param-name>cors.allowed.methods</param-name>
+          <param-value>GET,POST,PUT,DELETE,HEAD,OPTIONS</param-value>
       </init-param>
       <init-param>
-        <param-name>cors.allowed.headers</param-name>
+          <param-name>cors.allowed.headers</param-name>
+          <param-value>Authorization,Origin,Accept,X-Requested-With,Content-Type,Access-Control-Request-Method,Access-Control-Request-Headers</param-value>
       </init-param>
+      <init-param>
+          <param-name>cors.exposed.headers</param-name>
+          <param-value>Access-Control-Allow-Origin,Access-Control-Allow-Credentials</param-value>
+      </init-param>
+      <init-param>
+        <param-name>cors.support.credentials</param-name>
+        <param-value>true</param-value>
+      </init-param>
     </filter>
@@ -236,6 +242,11 @@
     </filter-mapping>
+    <filter-mapping>
+      <url-pattern>/*</url-pattern>
+    </filter-mapping>
     <!-- general initializer, should be first thing to execute -->
     <listener>
       <listener-class>org.geoserver.GeoserverInitStartupListener</listener-class>
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100229-sha1:634ba05)
Atlassian logo
