Dear ladies and gentleman,
When importing the attached layer over the REST API I receive the following error:
2023.07.05 15:43:32 TRACE [geoserver.platform] - Found System environment variable : ‘geoserver.xframe.policy’ to be unset
2023.07.05 15:43:32 DEBUG [geoserver.security] - Checking match of request : ‘Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes, QueryString: null’; against ‘/web/’
2023.07.05 15:43:32 DEBUG [geoserver.security] - Checking match of request : ‘Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes, QueryString: null’; against '/gwc/rest/web/’
2023.07.05 15:43:32 DEBUG [geoserver.security] - Checking match of request : ‘Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes, QueryString: null’; against ‘/’
2023.07.05 15:43:32 DEBUG [geoserver.security] - Checking match of request : ‘Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes, QueryString: null’; against ‘/j_spring_security_check’
2023.07.05 15:43:32 DEBUG [geoserver.security] - Checking match of request : ‘Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes, QueryString: null’; against ‘/j_spring_security_check/’
2023.07.05 15:43:32 DEBUG [geoserver.security] - Checking match of request : ‘Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com…8106…/featuretypes, QueryString: null’; against ‘/j_spring_security_logout’
2023.07.05 15:43:32 DEBUG [geoserver.security] - Checking match of request : ‘Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes, QueryString: null’; against ‘/j_spring_security_logout/’
2023.07.05 15:43:32 DEBUG [geoserver.security] - Checking match of request : ‘Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes, QueryString: null’; against '/rest/’
2023.07.05 15:43:32 DEBUG [geoserver.security] - Matched Path: /rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes, QueryString: null with /rest/
2023.07.05 15:43:32 DEBUG [geoserver.security] - AuthenticationCache found an entry for basic, admin:ccb4ecf763a262ab2c211945767c4dfd
2023.07.05 15:43:32 DEBUG [geoserver.security] - Converted URL to lowercase, from: ‘/rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes’; to: ‘/rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes’ and httpMethod= POST
2023.07.05 15:43:32 DEBUG [geoserver.security] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2023.07.05 15:43:32 DEBUG [geoserver.security] - Candidate is: ‘/rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes’; antPath is /; matchedPath=true; matchedMethods=false
2023.07.05 15:43:32 DEBUG [geoserver.security] - ~~~~~~~~~~ antPath= / methodList= [POST, DELETE, PUT]
2023.07.05 15:43:32 DEBUG [geoserver.security] - Candidate is: ‘/rest/workspaces/ws_aerodrome_adq/datastores/adqtemplate@anonymised.com/featuretypes’; antPath is /**; matchedPath=true; matchedMethods=true
2023.07.05 15:43:32 DEBUG [geoserver.security] - returning GROUP_ADMIN,ADMIN,Geoserver_Admin
2023.07.05 15:43:32 DEBUG [sqlserver.jtds] - Failed to find JTDS jar
2023.07.05 15:43:32 DEBUG [org.geoserver] - Thread 568 locking in mode WRITE
2023.07.05 15:43:32 DEBUG [org.geoserver] - Thread 568 got the lock in mode WRITE
2023.07.05 15:43:32 TRACE [geoserver.platform] - Found Property override: ‘GEOSERVER_XSTREAM_WHITELIST’ to be unset
2023.07.05 15:43:32 TRACE [geoserver.platform] - Found Java environment variable : ‘GEOSERVER_XSTREAM_WHITELIST’ to be unset
2023.07.05 15:43:32 TRACE [geoserver.platform] - Found Servlet context parameter : ‘GEOSERVER_XSTREAM_WHITELIST’ to be unset
2023.07.05 15:43:32 TRACE [geoserver.platform] - Found System environment variable : ‘GEOSERVER_XSTREAM_WHITELIST’ to be unset
2023.07.05 15:43:32 DEBUG [geotools.jdbc] - CREATE CONNECTION
2023.07.05 15:43:32 DEBUG [geotools.jdbc] - CLOSE CONNECTION
2023.07.05 15:43:32 ERROR [geoserver.rest] - Cannot invoke “org.geoserver.catalog.MetadataMap.get(String, java.lang.Class)” because the return value of “org.geoserver.catalog.FeatureTypeInfo.getMetadata()” is null
java.lang.NullPointerException: Cannot invoke “org.geoserver.catalog.MetadataMap.get(String, java.lang.Class)” because the return value of “org.geoserver.catalog.FeatureTypeInfo.getMetadata()” is null
at org.geoserver.catalog.impl.FeatureTypeValidator.validate(FeatureTypeValidator.java:40)
at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:515)
at org.geoserver.security.SecureCatalogImpl.validate(SecureCatalogImpl.java:1320)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.validate(AbstractFilteredCatalog.java:633)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.validate(AbstractCatalogDecorator.java:274)
at org.geoserver.rest.catalog.FeatureTypeController.featureTypePost(FeatureTypeController.java:280)
at jdk.internal.reflect.GeneratedMethodAccessor1625.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:150)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:117)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:808)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1072)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:965)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:555)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:623)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:209)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:153)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:178)
at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:328)
at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:158)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:73)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.HTTPMethodFilter.doFilter(HTTPMethodFilter.java:36)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:194)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:43)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:337)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:115)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:81)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:346)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:122)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:116)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:198)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilterInternal(GeoServerSecurityContextPersistenceFilter.java:72)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:221)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:186)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:54)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:167)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:481)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:130)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:673)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:390)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:926)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1791)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Unknown Source)
I send the Request as POST to the following URL: [https://[HOSTNAME]:8443/geoserver/rest/workspaces/WS_AERODROME_ADQ/datastores/ADQTEMPLATE@anonymised.com/featuretypes|https://gondev.gon.local:8443/geoserver/rest/workspaces/WS_AERODROME_ADQ/datastores/ADQTEMPLATE@anonymised.com/featuretypes]
In version 2.21.4 the request went fine. In 2.23.1 the request fails.
I also tried to send a fresh copy of a layer configuration GeoServer 2.23.1 generated, but receiving the same error. When I try to manually add the layer, the layer is working fine. The resulting .json via REST API looks exactly like the attached one.
