[Geoserver-devel] [jira] (GEOS-4908) WMS cascading does not work anymore if a proxy is required for external connections
Andrea Aime created GEOS-4908:
             Summary: WMS cascading does not work anymore if a proxy is required for external connections
                 Key: GEOS-4908
                 URL: https://jira.codehaus.org/browse/GEOS-4908
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
            Reporter: Andrea Aime
            Assignee: Gabriel Roldán
            Priority: Blocker
             Fix For: 2.1.3
Marking as a blocker since it's a regression compared to 2.1.2. I guess we should either setup code to use the proxies in commons-http client or allow the users to choose what http client library to use (the java built-in one should work provided system variables are set).
I guess the former would be better, especially if we start using the geotools HTTPClient abstraction in more places.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
