[Geoserver-devel] [jira] (GEOS-4914) Context initialization failed - Error creating bean with name 'gwcFacade'
Evan Martin created GEOS-4914:
             Summary: Context initialization failed - Error creating bean with name 'gwcFacade'
                 Key: GEOS-4914
                 URL: https://jira.codehaus.org/browse/GEOS-4914
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.3
         Environment: Windows 7 x64, JRE 1.6.0_30-b12
            Reporter: Evan Martin
            Assignee: Andrea Aime
            Priority: Critical
         Attachments: geoserver.log
After upgrading from 2.1.2 to 2.1.3a (by running the Windows installer) I can no longer start GeoServer. The following exception occurs every time. Log file attached.
2011-12-26 22:11:38,955 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcFacade' defined in URL [jar:file:/C:/Program%20Files%20(x86)/GeoServer/webapps/geoserver/WEB-INF/lib/gwc-2.1.3.jar!/geowebcache-geoserver-context.xml]: Cannot resolve reference to bean 'gwcTLDispatcher' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcTLDispatcher' defined in URL [jar:file:/C:/Program%20Files%20(x86)/GeoServer/webapps/geoserver/WEB-INF/lib/gwc-2.1.3.jar!/geowebcache-core-context.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.layer.TileLayerDispatcher]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcXmlConfig' defined in URL [jar:file:/C:/Program%20Files%20(x86)/GeoServer/webapps/geoserver/WEB-INF/lib/gwc-2.1.3.jar!/geowebcache-core-context.xml]: 2 constructor arguments specified but no matching constructor found in bean 'gwcXmlConfig' (hint: specify index and/or type arguments for simple parameters to avoid type ambiguities)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
  at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
  at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
  at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
  at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
  at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
  at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
  at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
  at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
  at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
  at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
  at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
  at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
  at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
  at org.mortbay.jetty.Server.doStart(Server.java:222)
  at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.mortbay.start.Main.invokeMain(Main.java:183)
  at org.mortbay.start.Main.start(Main.java:497)
  at org.mortbay.start.Main.main(Main.java:115)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcTLDispatcher' defined in URL [jar:file:/C:/Program%20Files%20(x86)/GeoServer/webapps/geoserver/WEB-INF/lib/gwc-2.1.3.jar!/geowebcache-core-context.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.layer.TileLayerDispatcher]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcXmlConfig' defined in URL [jar:file:/C:/Program%20Files%20(x86)/GeoServer/webapps/geoserver/WEB-INF/lib/gwc-2.1.3.jar!/geowebcache-core-context.xml]: 2 constructor arguments specified but no matching constructor found in bean 'gwcXmlConfig' (hint: specify index and/or type arguments for simple parameters to avoid type ambiguities)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  ... 43 more
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.layer.TileLayerDispatcher]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcXmlConfig' defined in URL [jar:file:/C:/Program%20Files%20(x86)/GeoServer/webapps/geoserver/WEB-INF/lib/gwc-2.1.3.jar!/geowebcache-core-context.xml]: 2 constructor arguments specified but no matching constructor found in bean 'gwcXmlConfig' (hint: specify index and/or type arguments for simple parameters to avoid type ambiguities)
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
  at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
  ... 55 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcXmlConfig' defined in URL [jar:file:/C:/Program%20Files%20(x86)/GeoServer/webapps/geoserver/WEB-INF/lib/gwc-2.1.3.jar!/geowebcache-core-context.xml]: 2 constructor arguments specified but no matching constructor found in bean 'gwcXmlConfig' (hint: specify index and/or type arguments for simple parameters to avoid type ambiguities)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:181)
  at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:881)
  at org.geowebcache.GeoWebCacheExtensions.extensions(GeoWebCacheExtensions.java:110)
  at org.geowebcache.GeoWebCacheExtensions.extensions(GeoWebCacheExtensions.java:130)
  at org.geowebcache.layer.TileLayerDispatcher.reInit(TileLayerDispatcher.java:109)
  at org.geowebcache.layer.TileLayerDispatcher.<init>(TileLayerDispatcher.java:59)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
  at java.lang.reflect.Constructor.newInstance(Unknown Source)
  at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
  ... 57 more
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
