[Geoserver-devel] [jira] (GEOS-4923) SCALE parameter not working properly getLegendGraphic
Simon Sandlund created GEOS-4923:
             Summary: SCALE parameter not working properly getLegendGraphic
                 Key: GEOS-4923
                 URL: https://jira.codehaus.org/browse/GEOS-4923
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.3
            Reporter: Simon Sandlund
            Assignee: Andrea Aime
            Priority: Minor
Example: I have a layer and a style with 2 rules.
Rule 1 has a MinScaleDenominator of 1 and a MaxScaleDenominator of 7500.
Rule 2 has a MinScaleDenominator of 7500 and a MaxScaleDenominator of 22500.
A GetLegendGraphic request with SCALE set to 7500 gives me graphics for BOTH rules, but MaxScaleDenominator is supposed to be exclusive.
Glancing at the code (I haven't stepped through it), I believe the bug might be found in LegendUtils's isWithinScale which has the expression:
{code}
return (scaleDenominator == -1)
      || (((r.getMinScaleDenominator() - BufferedImageLegendGraphicBuilder.TOLERANCE) <= scaleDenominator)
      && ((r.getMaxScaleDenominator() + BufferedImageLegendGraphicBuilder.TOLERANCE) > scaleDenominator));
{code}
The operators are correct, but thanks to the tolerance, if r.getMaxScaleDenominator() == scaleDenominator, this will still return true. My naïve guess would be to remove the tolerance. I couldn't find how it's done when actually rendering the layer... it should be done in the same way I suppose.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
