[Geoserver-devel] [jira] (GEOS-4926) When importing data, filter out features with invalid (null/infinity) coordinates
Matt Bertrand created GEOS-4926:
             Summary: When importing data, filter out features with invalid (null/infinity) coordinates
                 Key: GEOS-4926
                 URL: https://jira.codehaus.org/browse/GEOS-4926
             Project: GeoServer
          Issue Type: Improvement
          Components: Validation
    Affects Versions: 2.1.3
            Reporter: Matt Bertrand
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: Pugachev_context.zip
Some shapefiles contain features that have invalid (null/infinity) coordinates. When imported into geoserver, this causes the minimum XY coordinates for the layer bounding box to be calculated as -infinity,-infinity. Maybe these features should be filtered out of bounding box calculations, or removed entirely if importing into PostGIS via the REST API?
Attached shapefile contains 2 points with this problem.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
