Ben Caradoc-Davies created GEOS-4931:
Summary: Build failure in 2.1.x printing caused by Java 6 mapfish dependency
Key: GEOS-4931
URL: https://jira.codehaus.org/browse/GEOS-4931
Project: GeoServer
Issue Type: Bug
Components: Community modules, Hudson
Affects Versions: 2.1.x
Reporter: Ben Caradoc-Davies
Assignee: Andrea Aime
Priority: Blocker
The 2.1.x Hudson build is broken in printing by mapfish print-lib-1.2-SNAPSHOT.jar which has been built with Java 6. Please either remove the -Pprinting from the build or change the dependency to a Java 5 version.
From the test error:
Caused by: java.lang.IllegalArgumentException: Error loading class [org.mapfish.print.servlet.MapPrinterServlet]: problem with class file or dependent class.
Caused by: java.lang.UnsupportedClassVersionError: Bad version number in .class file
I checked the major version in the class file and it is 50 (Java 6).
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
