Mike Pumphrey created GEOS-4935:
Summary: Default Style box in layer group configuration page should be checked by default
Key: GEOS-4935
URL: https://jira.codehaus.org/browse/GEOS-4935
Project: GeoServer
Issue Type: Improvement
Components: UI
Affects Versions: 2.1.3
Environment: Wicket
Reporter: Mike Pumphrey
Assignee: Andrea Aime
Priority: Trivial
Fix For: 2.1.4
When creating a layer group, adding layers does not seem to trigger the default style to be used, thus causing the layer to possibly display differently when inside and outside of the layer group, and possibly causing a display error. I've often seen users tripped up by this mismatch. Checking the box for Default Style always resolves this, and harmonizes the view of the layer regardless of how/where it's being viewed.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
