Nathan Wiese created GEOS-4936:
Summary: Compute Lat/Lon Bounding Box gives incorrect result
Key: GEOS-4936
URL: https://jira.codehaus.org/browse/GEOS-4936
Project: GeoServer
Issue Type: Bug
Components: PostGIS
Affects Versions: 2.1.3
Environment: Windows 7 (64 bit), PostgreSQL 9.0.4, PostGIS 1.5.3
Reporter: Nathan Wiese
Assignee: Andrea Aime
Hallo GeoServer Team,
I created the following sample data in PostgreSQL/PostGIS:
CREATE TABLE swiss_city (id int, name varchar, PRIMARY KEY(id));
SELECT AddGeometryColumn('swiss_city', 'the_geom', 21781, 'POINT', 2);
INSERT INTO swiss_city VALUES (1, 'Bern', GeomFromText('POINT(600000 200000)', 21781));
When publishing the table as layer in GeoServer, I clicked on "Compute from data" for the
Native Bounding Box and got the following result:
Native Bounding Box:
599'999 199'999 600,001 200,001
Next, I clicked on "Compute from native bounds" which gave me an incorrect result for the Lat/Lon Bounding Box:
-82.48882871795712 -0.1731109797267328 -82.48880334534114 -0.173085436212199
In the log file, this warning/error appears:
2012-01-26 15:31:00,299 WARN [org.geotools.jdbc] - Failed to use ST_Estimated_Extent, falling back on envelope aggregation
org.postgresql.util.PSQLException: FEHLER: LWGEOM_estimated_extent: couldn't locate table within current schema
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
The same procedure in GeoServer 2.1.2 produces the correct result:
7.439 46.951 7.439 46.951
Best wishes,
Nathan
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
