Blake Crosby created GEOS-4954:
Summary: Legend Graphic fails when numberformat function in Label
Key: GEOS-4954
URL: https://jira.codehaus.org/browse/GEOS-4954
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.0.3
Reporter: Blake Crosby
Assignee: Andrea Aime
Priority: Minor
Using the following in a label for a rule results in a java exception.
<Label>
<ogc:Function name="numberFormat">
<ogc:Literal>##</ogc:Literal>
<ogc:PropertyName>temp</ogc:PropertyName>
</ogc:Function>°C
</Label>
Exception:
java.lang.IllegalArgumentException: Filter Function problem for function strConcat argument #0 - expected type String Filter Function problem for function strConcat argument #0 - expected type String
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
