[Geoserver-devel] [jira] (GEOS-4968) Creating a layer for a EPSG:32662 file failed.
Avotas created GEOS-4968:
             Summary: Creating a layer for a EPSG:32662 file failed.
                 Key: GEOS-4968
                 URL: https://jira.codehaus.org/browse/GEOS-4968
             Project: GeoServer
          Issue Type: Bug
          Components: Validation
    Affects Versions: 2.1.3
         Environment: Windows 7 64 Bit, 8 GB of Memory.
            Reporter: Avotas
            Assignee: Andrea Aime
When loading a 3.84 GB GeoTiff encoded with EPSG:32662 Native SRS is listed as "Unknown" when I declare the EPSG: 32662 and hit save or Compute from data in the binding box field I generate an error. See below. ArcGIS allows this dataset, and generates no errors.
Geotiff_Information:
   Version: 1
   Key_Revision: 1.0
   Tagged_Information:
      ModelTiepointTag (2,3):
         0 0 0
         -20037507.1 10018754.2 0
      ModelPixelScaleTag (1,3):
         764.425513 764.411108 0
      End_Of_Tags.
   Keyed_Information:
      GTModelTypeGeoKey (Short,1): ModelTypeProjected
      GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
      GTCitationGeoKey (Ascii,30): "PCS Name = World_Plate_Carree"
      GeographicTypeGeoKey (Short,1): GCS_WGS_84
      GeogCitationGeoKey (Ascii,13): "GCS_WGS_1984"
      GeogAngularUnitsGeoKey (Short,1): Angular_Degree
      GeogSemiMajorAxisGeoKey (Double,1): 6378137
      GeogInvFlatteningGeoKey (Double,1): 298.257224
      ProjectedCSTypeGeoKey (Short,1): User-Defined
      ProjectionGeoKey (Short,1): User-Defined
      ProjCoordTransGeoKey (Short,1): CT_Equirectangular
      ProjLinearUnitsGeoKey (Short,1): Linear_Meter
      ProjStdParallel1GeoKey (Double,1): 0
      ProjFalseEastingGeoKey (Double,1): 0
      ProjFalseNorthingGeoKey (Double,1): 0
      ProjCenterLongGeoKey (Double,1): 0
      ProjCenterLatGeoKey (Double,1): 0
      End_Of_Keys.
   End_Of_Geotiff.
Projection Method: CT_Equirectangular
   ProjCenterLatGeoKey: 0.000000 ( 0d 0' 0.00"N)
   ProjCenterLongGeoKey: 0.000000 ( 0d 0' 0.00"E)
   ProjFalseEastingGeoKey: 0.000000 m
   ProjFalseNorthingGeoKey: 0.000000 m
GCS: 4326/WGS 84
Datum: 6326/World Geodetic System 1984
Ellipsoid: 7030/WGS 84 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
Projection Linear Units: 9001/metre (1.000000m)
Corner Coordinates:
Upper Left (-20037507.068,10018754.204)
Lower Left (-20037507.068,-10018754.177)
Upper Right (20037500.455,10018754.204)
Lower Right (20037500.455,-10018754.177)
Center ( -3.306, 0.014)
org.apache.wicket.WicketRuntimeException: Method onFormSubmitted of interface org.apache.wicket.markup.html.form.IFormSubmitListener targeted at component [MarkupContainer [Component id = resource]] threw an exception
  at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:193)
  at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
  at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
  at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
  at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
  at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
  at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
  at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
  at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
  at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
  at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
  at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
  at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
  at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
  at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.reflect.InvocationTargetException
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
  ... 82 more
Caused by: java.lang.IllegalArgumentException: Parameter message can't be null
  at org.apache.wicket.feedback.FeedbackMessage.<init>(FeedbackMessage.java:102)
  at org.apache.wicket.feedback.FeedbackMessages.error(FeedbackMessages.java:135)
  at org.apache.wicket.Component.error(Component.java:1309)
  at org.geoserver.web.data.resource.ResourceConfigurationPage.doSave(ResourceConfigurationPage.java:271)
  at org.geoserver.web.data.resource.ResourceConfigurationPage$6.onSubmit(ResourceConfigurationPage.java:214)
  at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1561)
  at org.apache.wicket.markup.html.form.Form.process(Form.java:958)
  at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:920)
  ... 87 more
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
