[Geoserver-devel] [jira] (GEOS-4975) image pyramid plugin creates wrong tiles
Jean Pommier created GEOS-4975:
             Summary: image pyramid plugin creates wrong tiles
                 Key: GEOS-4975
                 URL: https://jira.codehaus.org/browse/GEOS-4975
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.3
         Environment: Ubuntu 11.04, geoserver 2.1.3, gdal 1.6.3
            Reporter: Jean Pommier
            Assignee: Andrea Aime
         Attachments: pyrPlugin-zoomlevel1.png, pyrPlugin-zoomlevel2.png
The output of image pyramids are sometimes bad : either no tile at all at a given level, or, worse, some transparent areas in the image. Not corresponding to a full tile (I'm always using tiled display in OpenLayers)
The source data are geotiff, and processed using GDAL (gdal_retile.py -v -r bilinear -levels 6 -ps 2048 2048 -co "TILED=YES" -co "BLOCKXSIZE=256" -co "BLOCKYSIZE=256" -s_srs EPSG:4326 -targetDir srtmpyr srtm.tif)
See attachments, or live at : http://ns387808.ovh.net:8080/geoserver-prod/ml/wms?service=WMS&version=1.1.0&request=GetMap&layers=ml:ml_v_1b_srtmpyr&styles=&bbox=-12.243333,10.160000000000055,4.2433336666666035,25.0&width=512&height=460&srs=EPSG:4326&format=application/openlayers
It should fit whole Mali country... and from one zoom level to another, is not consistent at all...
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
