Gabriel Roldán created GEOS-4983:
Summary: Make sure embedded GWC config gets reloaded when the GeoServer config is called for a reload
Key: GEOS-4983
URL: https://jira.codehaus.org/browse/GEOS-4983
Project: GeoServer
Issue Type: Task
Components: GWC
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 2.2.x
Now that the config for the embedded gwc layers is decoupled from the layer/group metadata map, make sure if the GeoServer configuration is called for a full reload, that the gwc config is also reloaded.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
