[Geoserver-devel] [jira] (GEOS-4984) layer groups in different workspaces with same local name show up with identical names in global wms capabilities doc
Justin Deoliveira created GEOS-4984:
             Summary: layer groups in different workspaces with same local name show up with identical names in global wms capabilities doc
                 Key: GEOS-4984
                 URL: https://jira.codehaus.org/browse/GEOS-4984
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration, WMS
    Affects Versions: 2.2.x
            Reporter: Justin Deoliveira
            Assignee: Justin Deoliveira
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
Hey Justin,
good stuff wrapping this up.
As a side note, it'd be good if local-workspace layergroups showed up
with prefixed names in the layer preview page. Otherwise it's hard to
notice which one to preview when you have two of them with the same
name.
Gabriel
On Wed, Mar 7, 2012 at 2:29 PM, Justin Deoliveira (JIRA)
            Key: GEOS\-4984
        Project: GeoServer
     Issue Type: Bug
Virtualization & Cloud Management Using Capacity Planning
Cloud computing makes use of virtualization - but cloud computing
also focuses on allowing computing to be delivered as a service.
http://www.accelacomm.com/jaw/sfnl/114/51521223/
Geoserver-devel mailing list
Gabriel Roldan
OpenGeo - http://opengeo.org
Done.
On Thu, Mar 8, 2012 at 7:24 AM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hey Justin,
As a side note, it’d be good if local-workspace layergroups showed up
with prefixed names in the layer preview page. Otherwise it’s hard to
name.
Gabriel
Key: GEOS-4984
Project: GeoServer
Issue Type: Bug
Gabriel Roldan
Justin Deoliveira
