Gabriel Roldán created GEOS-4987:
Summary: Make integrated GWC support LayerGroups local to a workspace - reconciliate with GSIP 73
Key: GEOS-4987
URL: https://jira.codehaus.org/browse/GEOS-4987
Project: GeoServer
Issue Type: Task
Components: GWC
Affects Versions: 2.2.x
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 2.2.x
GSIP 73 introduced the concept of LayerGroups local to a workspace, by adding a workspace property to LayerGroupInfo. Make sure the embedded GWC can deal with them.
This issue partially depends on GEOS-4985, as we discovered that prefixed layer group names are needed in order to avoid name clashes when not using a local workspace, regardless of GWC.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
