[Geoserver-devel] [jira] (GEOS-4991) Problem with WMSGetFeatureInfo request when map cross the 180 dateline
Phil Scadden created GEOS-4991:
             Summary: Problem with WMSGetFeatureInfo request when map cross the 180 dateline
                 Key: GEOS-4991
                 URL: https://jira.codehaus.org/browse/GEOS-4991
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.0.2
            Reporter: Phil Scadden
            Assignee: Andrea Aime
In a map that crosses the 180 line, WMSGetFeatureInfo returns no results
for features in Western hemisphere (right hand side of 180).
Eg
http://maps.gns.cri.nz/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&LAYERS=gns%3APETROLEUM.NZ_2D_SEIS_LINES&QUERY_LAYERS=gns%3APETROLEUM.NZ_2D_SEIS_LINES&STYLES=&BBOX=16731556.455301%2C-6475305.63131%2C21227276.710297%2C-3603719.353092&FEATURE_COUNT=1&HEIGHT=587&WIDTH=919&FORMAT=image%2Fpng&INFO_FORMAT=application%2Fvnd.ogc.gml&SRS=EPSG%3A900913&X=754&Y=363
returns null feature set.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
