Gabriel Roldán created GEOS-4992:
Summary: Make embedded tile layers react to layer bounds changes
Key: GEOS-4992
URL: https://jira.codehaus.org/browse/GEOS-4992
Project: GeoServer
Issue Type: New Feature
Components: GWC
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 2.2.x
What should happen to an embedded tile layer when the associated layer/group bounds change (by configuration)?
- obviously the tile layer bounds should reflect the new layer bounds
- if as a result of the bounds change existing tiles end outside the new bounds, should they be truncated?
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
