[Geoserver-devel] [jira] (GEOS-4997) Ability to watermark a single layer or layer group
David Alvey created GEOS-4997:
             Summary: Ability to watermark a single layer or layer group
                 Key: GEOS-4997
                 URL: https://jira.codehaus.org/browse/GEOS-4997
             Project: GeoServer
          Issue Type: New Feature
          Components: WMS
            Reporter: David Alvey
            Assignee: Andrea Aime
I have a situation where we are starting to use OS mapping data in geoserver which needs to be watermarked. When displayed on the website I use multiple dynamic layers to build up the map. If I apply a watermark to every layer then things will go horribly wrong but at present I see no other way of doing this.
Delivery has to be via wms and there are too many combinations of layers to serve them up in one go (unless it is possible to define a selection of layers in the javascript parameters).
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
