[Geoserver-devel] [jira] (GEOS-5007) Every call to CatalogConfiguration.getTile(layerName) forces the tile config to be depersisted from the file system
Gabriel Roldán created GEOS-5007:
             Summary: Every call to CatalogConfiguration.getTile(layerName) forces the tile config to be depersisted from the file system
                 Key: GEOS-5007
                 URL: https://jira.codehaus.org/browse/GEOS-5007
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.2.x
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.2.x
Every call to CatalogConfiguration.getTile(layerName) forces the tile config to be depersisted from the file system, hence affecting performance under load
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
