Gabriel Roldán created GEOS-5009:
Summary: Provide a way for the dispatcher to call a service operation avoiding reflection, for cases where it impacts performance
Key: GEOS-5009
URL: https://jira.codehaus.org/browse/GEOS-5009
Project: GeoServer
Issue Type: Improvement
Affects Versions: 2.1.3
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 2.1.4
Attachments: DirectInvocationService.patch, DirectInvocationService.png
When the OWS Dispatcher executes a service operation, it does so by using the reflective call {{Method.invoke}}. Now, both Sun JDK6 and 7 implementations come with quite a performance penalty in doing so (although Java7 a bit less than Java6), due to synchronized blocks inside {{Method.invoke}}.
This affects the performance of service operations that execute fast and are meant to be called by a large number of concurrent requests. Profiler shown they're blocked at this call for up to 70% of the time. For instance, I've been working on letting GWC tile requests engage into the Dispatcher so that it's possible to throttle them with control-flow.
The attached patch introduces an interface {{DirectInvocationService}}, that service beans can __optionally__ implement, so that the Dispatcher has a more direct way of invoking an operation than using reflection. So basically there's no difference for any existing service implementation other than an instanceof check at the Dispatcher itself, at least the service bean chooses to implement this interface.
The attached graph shows a performance comparison for the integrated gwc under different loads (with a hot cache):
- gray bars: the raw performance of the integrated gwc without going through the dispatcher
- red line: the performance when going through the Dispatcher as it is today (calling Method.invoke)
- green line: the performance after the gwc service implements {{DirectInvocationService}} and hence the Dispatcher doesn't call Method.invoke
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
