[Geoserver-devel] [jira] (GEOS-5010) Make GWC requests go through the GeoServer Dispatcher so they can be throttled by the control-flow module
Gabriel Roldán created GEOS-5010:
             Summary: Make GWC requests go through the GeoServer Dispatcher so they can be throttled by the control-flow module
                 Key: GEOS-5010
                 URL: https://jira.codehaus.org/browse/GEOS-5010
             Project: GeoServer
          Issue Type: New Feature
          Components: GWC
    Affects Versions: 2.2.x
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.2.x
All GeoWebCache requests other than "direct WMS integration" ones go through the GWC dispatcher, which is similar in spirit than the GeoServer OWS Dispatcher (but simpler).
This means GWC requests can't be throttled by the control-flow module.
Make it so that integrated GWC requests get handled by the GeoServer OWS Dispatcher, and hence they automatically engage into the control-flow module.
A mediator "gwc" service will be configured in the spring context, so that controlflow.properties can have a setting like:
{code}
ows.gwc=100
{code}
There will be a single "fake" operation in this service, named "dispatch", as it doesn't make sense to be able of setting different control flow limits for the different tile services. It's just more convenient to be able of setting a throttling limit for all gwc tile requests, regardless of whether the request is a WMC-C, TMS, or WMTS one.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
