[Geoserver-devel] [jira] (GEOS-5020) geowebcache and geoserver error
Enis ÖZGÜR created GEOS-5020:
             Summary: geowebcache and geoserver error
                 Key: GEOS-5020
                 URL: https://jira.codehaus.org/browse/GEOS-5020
             Project: GeoServer
          Issue Type: Bug
         Environment: windows 7 64 bit, jre 6 x64
            Reporter: Enis ÖZGÜR
            Assignee: Andrea Aime
Defaulting to 25% Heap Size
2012-03-22 09:24:30,075 INFO [storage.BDBQuotaStore] - Berkeley DB JE Disk Quota page store configured at C:\data_dir\data_dir\gwc\diskquota_page_store
2012-03-22 09:24:30,091 INFO [storage.BDBQuotaStore] - Quota Store initialized. Global quota: 0,0 B
2012-03-22 09:24:30,091 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: C:\data_dir\data_dir\gwc\geowebcache-diskquota.xml
2012-03-22 09:24:30,091 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2012-03-22 09:24:30,153 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2012-03-22 09:24:30,169 INFO [diskquota.DiskQuotaMonitor] - 23 layers attached to global quota 500,0 MB
2012-03-22 09:24:30,200 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2012-03-22 09:24:30,871 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2012-03-22 09:24:30,871 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job...
2012-03-22 09:24:30,933 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2012-03-22 09:24:31,121 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 9 paths
2012-03-22 09:24:31,199 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2012-03-22 09:24:31,199 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2012-03-22 09:24:31,277 INFO [org.geoserver] - GeoServer configuration lock is enabled
2012-03-22 10:10:49,336 INFO [seed.SeedTask] - GWC Seeder Thread-1 begins seeding layer : cite:Kahramanmaras
2012-03-22 10:10:49,344 WARN [layer.MetaTile] - ********* Native JAI is not installed, meta tile cropping may be slow ********
2012-03-22 10:10:49,406 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No service: ( gwc )
  at org.geoserver.ows.Dispatcher.service(Dispatcher.java:410)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:218)
  at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:834)
  at org.geoserver.gwc.layer.CatalogConfiguration.dispatchOwsRequest(CatalogConfiguration.java:309)
  at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:547)
  at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:521)
  at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:675)
  at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:129)
  at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:76)
  at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:36)
  at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:25)
  at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
  at java.util.concurrent.FutureTask.run(Unknown Source)
  at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
  at java.lang.Thread.run(Unknown Source)
2012-03-22 10:10:51,499 INFO [seed.GWCTask] - Thread group finished SEED task after 2.163 seconds
2012-03-22 10:10:51,499 ERROR [seed.MTSeeder] - Problem communicating with GeoServer
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
