[Geoserver-devel] [jira] (GEOS-5021) SLDs with RenderingTransformations which create attributes fail SLD attribute name checking
Martin Davis created GEOS-5021:
             Summary: SLDs with RenderingTransformations which create attributes fail SLD attribute name checking
                 Key: GEOS-5021
                 URL: https://jira.codehaus.org/browse/GEOS-5021
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.2.x
            Reporter: Martin Davis
            Assignee: Andrea Aime
When an SLD RenderingTransformation on a vector featuretype returns a new featuretype which has an attribute column not present in the input, and the SLD refers to the attribute name in the styling, the SLD attribute name checks issue an error message, and the SLD cannot be processed.
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
