[Geoserver-devel] [jira] (GEOS-5031) XY get swapped after a WFS-T Update with EPSG:3007
Sjoerd Brandsma created GEOS-5031:
             Summary: XY get swapped after a WFS-T Update with EPSG:3007
                 Key: GEOS-5031
                 URL: https://jira.codehaus.org/browse/GEOS-5031
             Project: GeoServer
          Issue Type: Bug
          Components: Global
    Affects Versions: 2.1.1
            Reporter: Sjoerd Brandsma
            Assignee: Andrea Aime
When using a CRS with northing,easting with a WFS-T update, the axis get swapped when crs style identifier is "EPSG:xxxx".
According to Gabriel Rolan this shouldn't happen:
Using the "EPSG:xxx" crs style identifier to mean "force X/Y lon/lat axis order"
Point INSERT with "EPSG:3007" results in XY readback in PostgreSQL --> Correct !
Point INSERT with "urn:ogc:def:crs:EPSG::3007" results in YX readback in Postgresql --> Correct !
Point UPDATE with "EPSG:3007" results in Y'X' readback in PostgreSQL --> Fail !
Point UPDATE with "urn:ogc:def:crs:EPSG::3007" results in Y'X' readback in PostgreSQL --> Correct !
More info can be found in this thread:
http://osgeo-org.1560.n6.nabble.com/XY-get-swapped-after-WFS-T-Update-with-EPSG-3007-td4667859.html
If you think it was sent incorrectly, please contact your JIRA administrators: https://jira.codehaus.org/secure/ContactAdministrators!default.jspa
